Im new to building and setting up cnc machines. I have power to all the motors, and the shafts will not turn, but motors will not jog in motor tuning. I have done all the necessary steps to set up mach3 according to the mach3 website video tutorials. The motors are getting warm to the touch as everything is powered, not sure if that is good or bad...
The setup I have is from Keling Tech 385 oz-in kit, with the 4030 drivers, 36v-8.8A power supply, and cnc4pc breakout board, all wired correctly...
One other question, I have a 5V dc power supply going to the breakout board, and I noticed when I plugged the 25 pin male to male cable to my computer, the light lit up, when the system was turned off... Is the printer port supposed to supply more power to the break out board?
Thanks!
Rob
