586,626 active members*
2,391 visitors online*
    Nov 2004
    4
    BP Series 1 CNC- spindle won't turn on
    Need help on my Bridgeport series 1 cnc. I finished a part on the machine and went to turn the spindle back on and it will not start. Everything else works fine. I read in the manual and all it says is to check lube level and its full and switch is working fine. Any ideas would be greatly appreciated. Thanks in advance.
    24223
    You will need the electrical schematic, what type of spindle? DC, AC, AC with VFD?
    Does it have an overload on the contactor that needs resetting?
    Al
    Albert E.
    Sep 2003
    552
    Check the overload reset on the spindle contactor. It's usually on the upper left side of the rear box looking from the front.
    Darek
    Nov 2004
    4
    Got it running. It was actually the switch. Should of looked at that first. Thanks for the info.
  1. Using your CNC Mill as a CNC Lathe
    By lstool in forum Knee Vertical Mills
    Last Post: 06-12-2017, 02:29 PM
  2. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  3. Spindle choice - Glass CNC
    By digital in forum DNC Problems and Solutions
    Last Post: 10-30-2004, 05:37 AM
  4. CNC Retrofit - Kit verses turn on and go
    By MetDetect in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2004, 04:06 AM
  5. CNC spindle and fluid control
    By replicapro in forum CNC Machine Related Electronics
    Last Post: 06-22-2004, 07:37 PM
