586,065 active members*
4,783 visitors online*
IndustryArena Forum > CAD Software > Solidworks > what is the best way to rename files in assemblies & sub assemblies.
Results 1 to 6 of 6
    May 2007
    327
    I need to completely rename most of the files in a large assemblies. what is the best way to rename files and sub assemblies. thanks much! R
    Sep 2005
    1660
    Um.. use the rename function.
    Open explorer and go to the folder in which the files are held. Right click a file and in the menu pane you'll see "SolidWorks -->" Click the arrow and you'll find three items, one is 'Pack & Go' the second is "Rename" and I don't remember the third off-hand... use the Rename and it will update the nesc linked components and assemblies to maintain the model.
    You could also do a pack and go, and rename them that way. By doing this you would duplicate the data and maintain the originals as they are.. at the least, I'd be making a backup of the entire model prior to doing either of these.. one small 'oops' and the model could go down the drain..
    For the record, you cannot just 'change' the name in explorer.. as it will break all associated links in the model.. it must be done via one of the two listed 'functions' above.
    Hth..
    JerryFlyGuy
    The more I know... the more I realize I don't
    May 2007
    327
    thanks
    i dont see a rename there only pack and go but will look around
    Sep 2005
    1660
    no problem..
    JerryFlyGuy
    Aug 2006
    259
    Quote Originally Posted by Rich05 View Post
    I was curious about this also, because the only thing I had in my right click menu was pack and go.. So I installed SolidWorks Explorer, and I have the options now..
    Pack and Go...
    Rename...
    Replace...
    HTH
    Just when you thought you had it all figured out, all hell breaks loose..
    Sep 2005
    1660
    Oh.. hrm well I've always had the SW explore installed... I rarely use it since I found this short cut.. We're not too far way from installing PDM Works here at the office so.. I suspect I'll be using SW explore more and more as time goes on...
    JerryFlyGuy
  1. Copied CW assemblies
    By almo0797 in forum CamWorks
    Last Post: 05-20-2008, 02:49 PM
  2. A question on assemblies
    By Craigpat in forum Solidworks
    Last Post: 11-15-2007, 05:30 PM
  3. DXF 2 Parts & Assemblies
    By bigz1 in forum Solidworks
    Last Post: 08-05-2006, 07:58 AM
  4. Equations in assemblies
    By teebee in forum Solidworks
    Last Post: 07-25-2006, 06:02 AM
  5. 2.5D parts, 3D assemblies
    By spalm in forum Uncategorised CAM Discussion
    Last Post: 06-09-2005, 01:36 PM
