586,060 active members*
4,300 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Full step and half step hybrid driver?
    Apr 2005
    81
    Just wondering if any drivers out there right now move full step for rapids and micro step for normal moves and precision positioning? I'm making a positioner that will have next to no load but requires an exact final position. I"m thinking i can full step much faster due to both processor requirements as well as motor limitations but once i'm within 1 full step switch to micro step to get it exactly where it needs to be. I could just stay in microsteps but i wanted faster transitions. Somebody let me know if this is possible or why it won't work.
    Jul 2006
    1062
    Try one of the mighty morphing Gecko ranger drives....They do afaik :cheers:
    Keith
    Apr 2005
    81
    Didn't realize they did that, so no issues doing this?
    The Geckos still need to be fed microsteps, but internally they convert them to full steps at higher rpm's.
    I think you're talking about outputting a combination of full steps and microsteps. Not sure how you'd go about that.
    Apr 2005
    81
    I'd be writing the software for the controller, sending the combination of full steps to micro steps won't be an issue once i determine the best way in the steppers view.
    Plan:
    Starting with a stepper in a micro step, i'd micro step to a full step position
    move at full steps to within one full step of final position
    then back to micro steps to the final position
    I am correct in that I will be able to attain higher RPM's full stepping right? This from only the stepper's point of view. I know the torque will increase which will help fight the drag in the system.
  1. TORQUE: FULL STEP vs half step
    By Glidergider in forum Stepper Motors / Drives
    Last Post: 02-27-2007, 09:02 PM
  2. Full/Half/Quarter/Eight Step Size?
    By pminmo in forum Polls
    Last Post: 01-11-2006, 07:31 PM
  3. Replies: 0
    Last Post: 08-26-2005, 07:22 PM
  4. stepper, half step, servo?? which to get?
    By blazer928 in forum CNC Machine Related Electronics
    Last Post: 04-13-2005, 06:28 PM
  5. Single Step/Half Step Question
    By Hawkeye in forum DIY CNC Router Table Machines
    Last Post: 11-20-2003, 05:28 PM
