586,233 active members*
3,078 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > Is there a way to generate CL code in Solidcam
Results 1 to 7 of 7
    Aug 2008
    Hi all,
    We are using solidcam and NX together in our machine shop. We have a millturn center. I have a custom made postprocessor for NX and want to use the same postprocessor for solidcam. If I can generate CL code in Solidcam, then the problem will be solved. Is there a way to generate CL code in Solidcam?
    Thank you...
    Oct 2007
    499
    I believe that there is post processor for SolidCAM that outputs text format APT. In a different life, what seems like a hundred years ago, I used to program in UniGraphics and then CATIA and both of them had the option to output cutter paths as either binary CL or text APT. I used a post processor created with G-POST from ICAM and that could take CL data in either binary or APT. This may be the way to achieve your goal.
    Your SolidCAM reseller should be able to get you the APT post
    Apr 2019
    8
    Re: Is there a way to generate CL code in Solidcam
    Hey Guys,
    Sorry for reviving a VERY old thread but I have a friend in need of a post for SolidCAM to output to APT or some type of CL data file. Any one out there can share a post or point me in the right direction?
    Thanks!
    Nov 2017
    44
    Quote Originally Posted by manussim View Post
    Hi all,
    Thank you...
    SolidCAM have own format instead CL code. Postprocessor have two files GPP and VMID.
    Apr 2019
    8
    Hello Danpil. I've done some research and have found out that much. I did also read that their was, at one time, a post (GPP/VMID fiels), that would output CL code. Do you have any experience with that? I have a machine that needs CL code for a specific application. We used to use Surfcam years ago but apparently something happened to the license. Any ideas?
    Thanks!
    Nov 2017
    44
    I don't think this is a good idea. Because there are drilling cycles, zero transfer cycles CYCLE 800 and other nuances. Can you share full CL code file?
    Apr 2019
    8
    Only need it for 3D Surfaces. Only X,Y,X AND I,J,K moves. See below for an example.
    *** SHORT SAMPLE ***
    PARTNO/0
    UNITS/INCH
    MCS/1.0000,0.0000,0.0000,0.0000,1.0000,0.0000,0.0000,0 .0000,1.0000,$
    MULTAX/OFF
    CUTTER/0.6250,0.0000
    LOADTL/2,LENGTH,0.0000,OSETNO,2
    SPINDL/RPM,4500,CLW
    COOLNT/FLOOD
    SELECT/0
    RAPID
    GOTO/81.6746,-1.1313,3.0000
    RAPID
    GOTO/81.6746,-1.1313,0.1000
    FEDRAT/IPM,20.0000
    GOTO/81.6746,-1.1313,-0.7500
    CUTCOM/LEFT,2
    FEDRAT/IPM,45.0000
    GOTO/81.7017,-1.1469,-0.7500
    FEDRAT/IPM,20.0000
    CIRCLE/81.2958,-0.9125,-0.7500,0.0000,0.0000,1.0000,0.4688
    GOTO/81.7645,-0.9125,-0.7500
    FEDRAT/IPM,45.0000
    GOTO/78.8865,-0.9125,-0.7500
    GOTO/78.8865,-2.4955,-0.7500
    GOTO/81.7645,-2.4955,-0.7500
    FEDRAT/IPM,20.0000
    CIRCLE/81.7645,-1.3813,-0.7500,0.0000,0.0000,1.0000,0.4688
    GOTO/81.2958,-1.3813,-0.7500
    CUTCOM/OFF
    FEDRAT/IPM,45.0000
    GOTO/81.3270,-1.3813,-0.7500
    FEDRAT/IPM,20.0000
    GOTO/81.6746,-1.1313,-1.5000
    CUTCOM/LEFT,2
    FEDRAT/IPM,45.0000
    CUTCOM/LEFT,2
    FEDRAT/IPM,45.0000
    GOTO/13.9465,-8.0635,-2.5000
    GOTO/14.4292,-7.6415,-2.5000
    GOTO/13.9465,-7.6415,-2.5000
    GOTO/14.1111,-8.2517,-2.5000
    GOTO/15.0950,-7.3915,-2.5000
    GOTO/13.6965,-7.3915,-2.5000
    GOTO/13.6965,-8.6142,-2.5000
    GOTO/14.2756,-8.4400,-2.5000
    GOTO/15.7608,-7.1415,-2.5000
    GOTO/13.4465,-7.1415,-2.5000
    GOTO/13.4465,-9.1648,-2.5000
    GOTO/14.4402,-8.6282,-2.5000
    GOTO/16.4265,-6.8915,-2.5000
    GOTO/13.1965,-6.8915,-2.5000
    GOTO/13.1965,-9.7155,-2.5000
    GOTO/14.2388,-8.7540,-2.5000
    FEDRAT/IPM,20.0000
    CIRCLE/14.1481,-8.2941,-2.5000,0.0000,0.0000,1.0000,0.4688
    GOTO/14.4566,-8.6470,-2.5000
    FEDRAT/IPM,45.0000
    GOTO/16.4931,-6.8665,-2.5000
    GOTO/13.1715,-6.8665,-2.5000
    GOTO/13.1715,-9.7705,-2.5000
    FEDRAT/IPM,20.0000
    GOTO/14.5917,-8.4454,-2.5000
    CUTCOM/OFF
    FEDRAT/IPM,45.0000
    GOTO/14.5621,-8.4354,-2.5000
    RAPID
    GOTO/14.5621,-8.4354,3.0000
    END
    FINI
  1. Camworks generate bad G-Code
    By beluga282 in forum CamWorks
    Last Post: 08-21-2015, 03:45 AM
  2. Generate g code with solidworks
    By romarlo in forum BobCad-Cam
    Last Post: 04-04-2014, 09:50 PM
  3. Looking for someone to generate me some code
    By JerryFlyGuy in forum Vectric
    Last Post: 08-17-2011, 11:29 PM
  4. What tools generate G-Code
    By eskimobob in forum LinuxCNC (formerly EMC2)
    Last Post: 09-30-2008, 02:54 AM
  5. Best way to generate code?
    By jderou in forum BobCad-Cam
    Last Post: 09-29-2004, 02:37 PM
