586,598 active members*
3,681 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Lynx 220a or 220c reccomendations
    Jan 2007
    46
    Hello, I have a one man shop and am interested in adding cnc lathe work to my shop.
    I have been looking at used cnc lathes, talked to a dealer today and was surprised the deal I could get on a brand new Lynx.
    I am unsure whether to get the 220a or 220c.
    The 220c gives you an 8 inch chuck instead of 6 inch chuck and a 2.625 bar capacity diameter versus 1.75 for the 220a.
    The 220a is 6000rpm where the 220c is only 4500rpm.
    I am a small job shop and undecided which to get since I currently do not do any cnc lathe work.
    I can get a much better deal on the 220a, and also a tailstock.
    Any reccomendations greatly appreciated.
    Thanks, Joe
    Feb 2007
    246
    I was in the exact same situation as you and we went with a used Lynx 200, with the tail stock and 6" chuck. For the work we were doing the diameter was not the problem but the fact that the Z travel is short. The most we could bore was about 5.5" deep because the travel was only about 12".
    If it is a lot cheaper and you think it will work for your sizes go for the little one, but then again even 4500RPM is plenty enough speed.
    Daewoo are good machines though, unfortunately I got stuck with a Mitsubishi controller.
    Live free or die
  1. Haas Lathe Reccomendations
    By imwllc in forum Haas Mills
    Last Post: 04-05-2012, 06:21 PM
  2. Upstroke press brakes - Reccomendations?
    By PhoenixMetal in forum Bending, Forging, Extrusion...
    Last Post: 07-27-2008, 09:48 PM
  3. lynx 220
    By wilko in forum Daewoo/Doosan
    Last Post: 02-02-2007, 03:26 PM
  4. Lynx 220A question
    By PBMW in forum Daewoo/Doosan
    Last Post: 12-27-2006, 01:24 AM
  5. Reccomendations
    By milford in forum DIY CNC Router Table Machines
    Last Post: 10-14-2004, 08:57 PM
