586,117 active members*
3,566 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > WTK: Trico "Micro Drop"
Results 1 to 20 of 20
    383
    I am looking at shop coolant / lube options for light milling and turning. Does anyone have any experiences with "micro-drop" types of systems which thay would like to share? What do these do? Does it simply apply a drop of cutting lube every second or so? Or is it augmented with air blast?
    I've heard good things in the past about these systems, just wanted to check before dropping $400+. Thanks!
    4826
    Hi Swede,
    Yes I use these systems. They do not apply a drop, it is a continuous "spray" but is totally non-misting from the nozzle. It is basically just a siphon, with all the "smarts" in the nozzle design: air flow around the outside of the oil nozzle induces the lube to flow.
    383
    Thanks Hu. Am I correct in thinking that this systems ability to clear chips is pretty limited? How close does the nozzle need to be to the cutter to get good distribution of lube?
    And the obvious question - are you happy with the performance of the system? Thanks for your replies.
    4826
    The nozzle clears chips quite well, but it does need to be within 4 to 6 inches of the cutter, I would say, to be effective at putting the lubricant where it is needed.
    Don't count on this type of system for supreme cooling efficiency, because it doesn't cool any better than a very small air line would. But it's good for aluminum milling. It will move the chips from steel milling, too, but the oil does create smoke on really hot chips.
    Oct 2004
    21
    Does this thing provide it's own air supply or do I have to have a seperate shop compressor? And, at $400, does anyone know a good source for this beast?
    383
    You need a compressor. I bought mine on eBay. So far it seems pretty nice. If you can, get the model with solenoid valves, allowing for remote on/off.
    Oct 2004
    21
    Sorry. Did you mean you got the compressor or the md-1200 on ebay?
    Apr 2003
    1079
    Swede, I bought my Trico unit on ebay for around $250. Nothing wrong with it at all, except for the smell of old oil! They are few and far between, but it may be worth a quick look before you fork out for a new unit.
    383
    Sorry, I bought the Micro-Drop on eBay, NIB, for something like $250. As Kong says, they are scarce. Set up a search for "Trico" in the Industrial section which will deliver about 30 to 40 Trico products, and scan them for the micro-drop system. Air consumption (relative to a home shop) is not low, so it's best that you have a pretty stout vertical compressor or you'll cycle your smaller compressor frequently.
    One objection - the lube is nearly invisible; it's hard to adjust it on the fly. I think it's best to preset it by spraying at a plate or table, noting the lube delivery, then not messing with the air and lube knobs, just turn it on and off.
    4826
    One thing I've noticed, too, is that after a time, the old oil may clog the nozzle ( I use the vegetable oil product). You need a tiny drill to drill out "the cheese" (by hand) and then it should work okay. I generally use the unit at a very low drop setting (2) and that seems like lots of oil, AFAIC. Any more gets to the point of becoming a mess.
    Oct 2004
    21
    Okay, here's some fresh information for anyone looking to go this route.
    The ebay offering for these units is very slim indeed. I set a search but still no hits. Finally ordered from http://www.jtsmach.com/jtswebshop/Fluids/FC068.asp. They have the best price I could find on the net but their service was... let's just not go there. Ask for drop shipment right off the bat AND the tracking number because they don't stock the units.
    The unit comes with a pint of vege-oil lube which is more than enough to test and run. Shop around for fluids later (only comes in gallon size).
    Some things to get while waiting for shipment are:
    1) 1/4" npt air hose.
    2) misc couplers since unit's air port is a female 1/4" npt nut.
    3) air filter, if you are worried about your compressor's air quality. I got one since I don't want to clog the tiny jets with gunk. The filter may have female ports which don't leave enough clearance to your compressor output so get a 2-3" 1/4" pipe from the plumping dept.
    4) Teflon tape to make all your connections leak free.
    5) Air compressor. Now here's the tricky part. The trico is $400. If you don't already have a compressor, figure in another $400. I have a dewalt 4gal (D55152) which will work but not recommended because the motor will cycle every 2-3 minutes with a 15 sec recharge time. Ideally, you'd like to cylce less than 20 times per hour for good compressor life. The trico is pushing it. Swede was right about having a stout compressor. More to come on this one.
    Jet placement is easy using the included magnet support and snaplock nozzle. The cuts I've made are a lot smoother than without cooling. I have an issue with the fluid wanting to drain back into the unit overnight but it's still early on that one.
    --Michael
    383
    Good observations Michael, I concur. May I add, you might want to include the following between the compressor and the Trico...
    - A manual ball valve for easy shutoff overnight rather than keeping the line pressurized
    - For automation, a 24V (or whatever) solenoid valve AFTER the compressor output filter and ball valve, and just PRIOR to the Trico. The Trico on/off manual switch can be left on in this case, and the solenoid valve operated via CNC.
    So far I like the unit. The compressed airflow alone helps cool and clear some chips. Definitely very miserly with the lube, and ZERO fogging. But it is a bit of an air pig, relating mainly to a typical home shop compressor. A "professional" AC in a bigger shop won't have the slightest problem. But if you have a pancake compressor or similar, you'll need to upgrade. I wouldn't try it with anything less than about 6 CFM at 100 PSI, just a WAG there.
    Oct 2004
    21
    Well, look what the fisherman just brought in.... http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7502338871
    Too bad I just got my unit setup. Maybe someone else can take advantage of this.
    (no affiliation... just post for those interested)
    Oct 2004
    21
    Is anyone having this problem with their trico units? I have a manual unit and when I use the cutoff switch, the air and coolant flows stop but the tip will drip coolant. Is this normal?
    In my setup, the trico unit mounted above the mill with the nozzle and lines running down to the cutter. I'm guessing the drip is due to gravity. I initially had the trico mounted level with the mill base and routed the hose lines up the enclosure wall and then down to the cutter... but this caused the coolant to siphon back into the unit over night... which means re-priming.
    My solution is to bend the snaplock line up so that the tip is level with the trico unit. This seems to alleviate the siphoning and drip problems.
    Oct 2004
    21
    Swede,
    I don't understand the ballvalve suggestion you gave above. Can you ellaborate?
    My current routine is to shut off the manual trico switch, close the trico air flow knob, and then purge the AC tanks for the evening.
    If the manual switch is on, the reservoir is pressurized and will continue to drip fluid right?
    Dec 2004
    524
    Quote Originally Posted by mdoan
    I suggest you have its prostate checked.
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    383
    Mdoan, here's a picture. I leave portions of my shop air manifold pressurized, so this setup simply cuts pressure to the Trico, otherwise the internals of the device are at 100 PSI day and night.
    The white line to the filter/regulator (lower left) is the input to the Microdrop. Off the photo, in the white poly line, is a simple ball valve. If I were to put a solenoid valve in this setup, I'd cut the yellow line and install it there.
    I think this unit pretty much needs a decent filter, as the lines inside the tip are pretty small.
    HTH
    Jan 2007
    525
    I recognize that this thread is from 2005 but would love to get some guidance on which coolant (MD-1 vegetable-based or MD-7 advanced synthetic) to purchase with my Trico MD-1200.
    The unit will be used to cool a hobby CNC mill. 90% of the time I cut 6061 aluminum; the remaining 10% is for 1018 and 4140 steel/alloy (with the coolant being much more important for cutting steel). I've read various descriptions and googled with no definitive opinions on which is best. Since they are both $80/gallon, it's a bit expensive to buy both and experiment...
    Thanks.
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    4826
    I can't think of a real recommendation for you, either one works fine. You might look around for a liter or quart size bottle, as even that amount will last a long time.
    I would not really class these as coolant, more as machining lubricants. The air does a bit of cooling, and the oil helps keep aluminum from sticking to the tool. Only a very small amount of oil is applied.
    Jan 2007
    525
    Hu - thanks for chiming in! I just spoke with a very nice fellow at Trico who explained that although either would work just fine, he recommended the synthetic over the vegetable simply due to ease of clean up. As Hu said, most of the time there is only a very small amount of oil applied, which is effectively evaporated by the cutter. But if you did have to clean up some of the fluid, synthetic only requires warm water & soap. Vegetable apparently requires close-to-boiling water. Not my personal experience, just relaying what the Trico fellow said.
    My unit should arrive late this week/next week. I'll be sure to post photos and more!
