Originally Posted by
aarggh
Also, are you sure it's an ER16 collet? I ask because normally ER16's only go up to .4375" and the standard calls for the very outside diameter to be just .65". There's no way you'd get a 1/2" bit in a standard one of those? And ER16 also seems very small for a 3kw. Usually once you hit 2.2kw and above, it's an ER20, you do see some ER16's on a 2.2kw, but not that often I find. But on a 3kw, that would just be a waste.
My mistake, you are correct, It was an er20 collet and my columbo has an er25 collet on it.
Out of curiosity, what do you normally machine with such a long Z? It's massive!
cheers,
Ian
