586,035 active members*
3,712 visitors online*
    Jul 2007
    Question Strange Behavior.
    Hi
    I just finished assembly my router table, finishing all the wiring, Installed the software (Mach3 VerR1.83.027)
    My system is as follow:
    3 KL6050 Stepper Drivers Keling Technology
    3 KL34H295-43-8B
    1 C10 Bidirectional breakout board from CNC4PC
    Desktop running under windows XP Home edition
    I was able to jog x and y axes, DRO moves, motors moved everything went really well. After trying jog z axes that's when my problem comes up. if a try jog x oy y the router only moves in one direction.
    I did this too:
    G0Z100 then my z axes moves 100mm DRO shows 100, looks real good!!! then G0Z0 then DRO backs to Zero but physically the X and Y axes moved and the z axes never moved Wrong!!!!!
    I've been checking all the wiring and everything look fine. My problem shows up when a start using my third axes......What else could I check???????
    Jul 2005
    969
    recheck your wire, i had a hell of a time getting my kl6050 to work ill post my wirring scheme tomorrow, but by the way this should be in the kelling forum
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Jul 2005
    969
    actually can you post how you got it wired
  1. Erratic motor behavior
    By KsiR in forum Stepper Motors / Drives
    Last Post: 06-03-2010, 09:15 PM
  2. Milltronics strange behavior
    By KBHone in forum Milltronics
    Last Post: 12-10-2007, 12:00 AM
  3. Strange circle behavior, 151B control
    By swarf_rat in forum Bridgeport / Hardinge Mills
    Last Post: 07-16-2007, 03:08 AM
  4. Bridgeport - Interact 1 MK2 - Abnormal Behavior
    By palikalsi in forum Bridgeport / Hardinge Mills
    Last Post: 02-28-2007, 04:15 PM
  5. odd stepper behavior?
    By opusinwood in forum Stepper Motors / Drives
    Last Post: 07-05-2006, 01:30 PM
