586,103 active members*
3,398 visitors online*
    Dec 2005
    43
    Router bits, End mills v bits
    I have router bits straight spiral bits.
    But what do you guys use for end mills, are these for a milling machine that you cut steel with? Ball end mills ect.
    Where can I get some?
    Nov 2006
    303
    There are lots of places to get tooling Online (enco,msc,vortec). There may even be a local tool grind shop in your area. Just depends on where your at. Google "tool grinding Canada". Or some variation and you bound to come across something.
    I get my tooling at http://pgm-tools.com/ Which happens to be down the road from us. Metal cutting tools will work fine for wood or HDU.
    Gets a little different when you cut acrylic, plastic, etc.
    I use an "O- flute" (single flute).
    Most my side cutting tools are 2 flute and 3 flute for v-carving.
    A) 1/2: up shear end mill
    B) 1/2: compression
    c) 1/2: down shear
    D) 1/8: 5 deg taper (draft)
    E) 1/2: Ball endmill
    F) 3/16: Ball mill 5 deg taper (draft)
    G) 1/2: 90 deg included angle (v-carve)
    H) 3/4: 120 deg included angle (v-carve)
    Hope this helps.
    Todd
    www.innovative-accents.com
    Dec 2005
    43
    bits
    Thanks I seen pieces cut with a ball end mill and could'nt find any on the wood cutting sites.
    Nov 2008
    129
    Milling cutters suppliers
    If you want some good quality tools try these as the have a Canadian office http://www.sgstool.com
  1. Which Router bits to Use
    By joecnc2006 in forum WoodWorking Topics
    Last Post: 05-06-2011, 11:06 AM
  2. router bits
    By luther in forum DIY CNC Router Table Machines
    Last Post: 09-04-2007, 12:50 AM
  3. Router Bits in OZ
    By Exelanoz in forum Australia, New Zealand Club House
    Last Post: 11-18-2005, 03:41 AM
  4. End mills engraving bits
    By signIT in forum Material Machining Solutions
    Last Post: 09-13-2004, 04:45 AM
