586,071 active members*
3,900 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Metal end mill for wood ?
Results 1 to 9 of 9
    Nov 2008
    4
    Hello,
    I have a small 3axis CNC router with a Kress 1050 (6 mm) spindle
    Here in Portugal it´s quite difficult to find end mills for wood, but quite easy to find end mills for metal.
    Is it possible to use a mill intended for cutting metal for cutting wood ?
    What would be the best compromise ?
    Thank you beforehand
    João
    2010
    I've had no problem cutting wood with tools intended to cut metal. Where I have had a problem is in using those tools in a router with a chuch rather than a collet. The spiral of the tool tends to pull itself into the work and out of the chuck and there by losing zero.
    I've had good luck regrinding broken carbide tools into a shape good for wood work.
    Good luck!
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
    Nov 2008
    4
    Thank you !
    Should I try to use a 2 flute end mill, or could a 4 fluted mill (easier to find over here) work ?
    Regards
    João
    2010
    My experience has been that softer material needs fewer flutes in order to have more room for chip to move. If cutting all the way thru material then a down spiral would be useful.
    The long and short of it is don't be afraid to try something and by all means use what works best for you. (may be different form everyone else) And just look at the fun you will have learning! :->
    Nov 2008
    4
    Smile
    Many thanks for your reply and insights !
    Regards from Portugal,
    João
    May 2008
    6
    metal milling bits
    My experience has been that if you can keep the rpm's under 2200 then their
    is no problems. When I try this in my router cnc equipment and the slowest speed is 12000 it tends to burn the bit and has also burned the wood.
    ken
    Jul 2007
    I have no troubles at all with end mills meant for metal, I run 1/8" and 1/4" up and down spirals at 16,000rpm in hardwoods. Feed speed in the 2.5ips range. Depth of cut varies with holddown method being used, and accuracy desired
    Nov 2008
    4
    Many thanks for your replies !
    I will report here my own experiences as soon as I have enough useful data.
    João
    Jan 2016
    33
    I use 3/4 metal cutting endmill roughers with 4 flutes. To do most of my wood roughing. As long as you can maintain a good chipload and sfm. Usually lowering your rpms. Ive had no problems with them at all. I have a spindle and vfd that can go as low as 5000 rpms though
  1. Wood or metal
    By cncman2 in forum DIY CNC Router Table Machines
    Last Post: 08-04-2013, 04:29 AM
  2. Wood and Metal CNC
    By Eric51 in forum Uncategorised MetalWorking Machines
    Last Post: 09-08-2010, 12:53 AM
  3. Metal With a Wood Router???
    By Sanghera in forum DIY CNC Router Table Machines
    Last Post: 03-07-2008, 07:44 PM
  4. cnc machine wood &metal combo
    By lawwdoggy in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2007, 06:21 AM
  5. Wood and metal router
    By kenlambert in forum DIY CNC Router Table Machines
    Last Post: 10-27-2004, 03:36 AM
