586,121 active members*
3,556 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Adjusting ballscrew bearing blocks
    May 2007
    1026
    My X2 uses 2 3/8-24 jam nuts on the end of each screw to secure it in th bearing block. I am finding that if I adjust it to have no backlash but still turn smoothly, the jam nuts will start to work themselves loose pretty quickly. I tried a star washer but that did nothing. My next thought is some blue loctite or a nylock. Any other ideas?
    Jun 2006
    2512
    You should have one nut thicker than the other. The thin one goes on first. It's more important than you might think.
    Phil
    Quote Originally Posted by sansbury View Post
  1. RFQ: ballscrew bearing blocks/flanges
    By margni74 in forum Employment Opportunity
    Last Post: 08-17-2007, 10:08 PM
  2. Cheap source for Ballscrew Support Blocks?
    By geocentric in forum Linear and Rotary Motion
    Last Post: 06-29-2006, 01:00 PM
  3. THK SSR20 Bearing Blocks wanted in UK
    By santiniuk in forum European Club House
    Last Post: 03-13-2006, 10:59 AM
  4. 2- Micromill bearing blocks and mounts.
    By radicooldude in forum Employment Opportunity
    Last Post: 01-14-2006, 04:51 AM
  5. RFQ Simple Aluminum Bearing Blocks
    By b0gh0s in forum Employment Opportunity
    Last Post: 12-23-2004, 10:57 PM
