586,121 active members*
3,032 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jul 2004
    36
    RC landing gear parts
    Here is my interest in metalwork for the hobby.
    Attached Thumbnails Attached Thumbnails sixthF104gear 223.jpg   sixthF104gear 242.jpg
    6855
    I was just talking to my good friend (the owner of rcuniverse.com) about machining wheel hubs for giant scale planes when I saw your post. Nice stuff, what plane is that did you scratch build it?
    Apr 2003
    1873
    Impressive ps2727 !
    Jul 2004
    36
    Thanks for the kind words..
    The plane is an F104 designed, built, and flown by Jerry Keller. My only contribution was the gear set. Quite an impressive project. I'll try to find a photo of the completed model.
    Paul
    383
    Paul, what are you doing messing with digital cameras and "toy" airplanes? Get your rear into the shop and finish that BP CNC conversion! Rather than hand-make these gear, you could be ripping them out by the dozen.
    Oh yes, when I make my move and have that jumbo hangar available, you'll be welcome to park that big, bulky, BP in there. I won't touch it, I promise.
    Back to work!
    Jul 2004
    36
    Oops, busted!
    I suppose I'll have to do as he says since he's been patiently mentoring me for a while now.
    If you're building a hangar we need to go shop for more tools!
    grasshopper
    Jul 2004
    36
    Here is a shot of the completed F104 model-- you'll have to trust me that the gear really is in there.
    Very nice!
    Proud owner of a Series II Bridgeport.
    Mar 2005
    Do you have your own shop? Nice work would lick to see it in pr ogres.
    May 2004
    600
    Absolutely impressive! Can you give us a rough idea of the diameter of the wheels or the length of the arms, plus the approximate length or wingspan of the plane (just guessing is fine) so we can get a feel for the size?
    Skippy
    Jul 2004
    36
    Here are a couple of shots of the gear. The model is to 1/6 scale so the fuse is 108 in. and the main leg is 7 in.
    I made a mockup in wood to verify the fit. Then drew it up and started cutting.
    The other gear is for a large B-58.
    I think these projects will go better when I get the CNC done!
    Paul
    Attached Thumbnails Attached Thumbnails sixthF104gear 010 (Small).jpg   sixthF104gear 131 (Small).jpg   sixthF104gear 213 (Small).jpg   DCP01064 (Small).JPG
    May 2004
    600
    Tell me it's not true? When I look at picture number 2 in large view it seems that it has a backing plate (i.e. non-rotating) which has a small nipple sticking out of it which would indicate that it even has some kind of brake assembly in side. Probably actuated by compressed air seeing as it's a model. Great work! As Swede said, get cracking with your cnc to start cranking out all sorts of bits by the dozen.
    Skippy
    p.s. The rims appear to be cast or if not maybe turned then particle blasted. Is that the case?
    Aug 2003
    812
    Yes, I used to fly 1/3 scale here in Phoenix and several guys at the field had jets with pneumatic brakes.
    I don't think it gets any cooler that a scale RC jet (with brakes no less), serious. That just brings out the giddy kid in every guy.
    I'd go so far as to say that any guy that did not get a big goofy grin on his face when he saw one of those things must have something wrong with him.
    Nice job!
    Jul 2004
    36
    You are correct, it has a pneumatic brake which is simply an "O" ring in a groove. The tire and wheel are purchased and are made with an internal bore for such a brake.
    This is the only photo I have which shows the o ring groove taken during one of the many (!) test fits. I suppose I need to take more photos in the future. And I found a great in flight shot of the model on the net.
    Thanks for the compliments.
    Paul
    Attached Thumbnails Attached Thumbnails sixthF104gear 148 (Small).jpg   Bz77230 (Small).jpg
    Dec 2005
    5
    Hi..
    What way is the system activated? Pnuematic?
    Declan
    Sep 2005
    24
    I second that question, plus did you make the cylinders/valves yourself?
    I'm looking into making some low pressure hydraulics (ie less than 10 bar) but i don't really know where to start
    Jul 2004
    36
    Scud,
    The system is pneumatic and operates at about 100 psi, which is normal for most RC retracts. I used 5/8 in diameter air cylinders from Robart -- the cylinders I've made are not up to the standard necessary to work reliably!
    Hydraulic systems are being developed and I think there is one on the market; I would be interested to hear of your progress.
    Paul
    Sep 2005
    24
    I'll keep you updated, but don't get your hopes up too much, i'm a complete beginner in this domain, yet a fast learner
    Still waiting for a delivery of aluminum stock...
    Jul 2004
    36
    Smile
    I put a short video of the gear operating during development. Sorry, it's pretty crude video. And yes, I did get them working together!
    Paul
    http://video.google.com/videoplay?do...86188112&hl=en
    Jul 2004
    36
    Here is my latest gear project, the C-119. I have access to the real thing which makes modeling it much easier.
    Here is a link to a short video.
    http://www.youtube.com/watch?v=cJ4wDQp_F38
    Paul
    Attached Thumbnails Attached Thumbnails new 395 (Small).jpg   new 379 (Small).jpg   new 368 (Small).jpg   new 393 (Small).jpg
Page 1 of 2 12
  1. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum Uncategorised CAM Discussion
    Last Post: 04-05-2012, 03:55 PM
  2. Small Parts Need High Accuracy
    By OneCNC in forum OneCNC
    Last Post: 06-21-2006, 03:18 PM
  3. NASA gear bearing by mister Vranish
    By wolphje in forum MetalWork Discussion
    Last Post: 07-28-2005, 07:28 PM
  4. gear pitch
    By 2muchstuff in forum Mechanical Calculations/Engineering Design
    Last Post: 04-02-2005, 03:04 PM
  5. 2 parts needed: gear and insert
    By SimonArthur in forum Employment Opportunity
    Last Post: 03-12-2005, 11:20 PM
