586,103 active members*
3,474 visitors online*
Results 1 to 7 of 7
    Dec 2007
    33
    deep part off w/peck help
    I'm trying to part off an 8.0" diameter nylatron rod. The G75 cycle on our
    SL 30 is only stopping, then restarting the groove, as opposed to stop/retract/restart as in a peck drilling cycle.
    How do I get the part off blade to retract 0.01 -0.02 before continuing?
    any help would be great.......
    Jul 2005
    12177
    According to the Haas manual the retract distance for G75 is controlled by Setting 22.
    Dec 2007
    33
    Thanks, Geof, I'll run out to the shop and try it.
    C
    4826
    This is a bit off topic, but what kind of partoff tool can you find that will reach 4 inches? I've shopped around a little, and have only found the standard 6" blade (which will reach 3" radius if you baby it) and the next increment blade seems to be some gawdawful thing that will part off a 24" bar taking a cut 1/2" wide
    Nov 2005
    1468
    I could use that information too please, I was trying to part off a 6" dia bar and the noise the machine was making would have woken the dead!
    I ended up hacksawing it which took forever.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Nov 2007
    1702
    He did say Nylatron, not Alumatron. I'd bet that the parting tool doesn't need to be very robust to cut plastic.
    Nonetheless, I'm waiting for an answer too. Always learning in here.
    Greg
    Dec 2007
    33
    There is a 1.375" diameter bearing in the center, so I'm not going in the full
    4 inches. I was cheating a std. 6 in. blade out to its veritable limits, which, would only work on plastic. The problem has been with the insert pulling to the right a little, giving me an undesirable conccave surface instead of flat.
    I did find an older style HSS blade .250 wide and 10" long. It should be here today. I'll just have to make a holder for it.
    Chris
  1. To Peck drill or not to peck dril.....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 08-23-2008, 05:33 PM
  2. Peck Drilling Help
    By soonervols in forum G-Code Programing
    Last Post: 06-09-2008, 12:26 PM
  3. v22 peck drilling
    By 68sixspeed in forum BobCad-Cam
    Last Post: 04-03-2008, 10:17 PM
  4. Peck Drilling
    By RBrandes in forum Haas Mills
    Last Post: 06-19-2007, 01:03 AM
  5. Peck drilling
    By LarryMiran in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-23-2004, 11:12 PM
