586,070 active members*
3,517 visitors online*
    Jan 2007
    122
    1992 VF2 Wieght
    Does anyone have an idea of the weight of an 1992 VF2? I am going to need to reant a forklift and I need to figure out how much I need to lift.
    Jan 2007
    122
    I see the newer ones are about 8000-9000 lbs but this is the older plactic inclosure and I was wondering if it was different.
    Dec 2008
    1992 Haas VF-2 weights 6000 lbs.
    Jul 2005
    12177
    Slightly under 8000lbs. You need a minimum of 10,000lb foklift with 8feet forks; it is better to go with 12,000 or 16,000lbs.
    The big problem with lifting these things is not weight it is the location of the center of gravity way out on the forks; especially if you come in from the front. A 10,000lb forklift will lift okay from the back, a bit wobbly from the sides and from the front it is possible it will tip.
    Quote Originally Posted by Geof View Post
    I just bought a VF-0E, do you think the 10k forklift
    I rented will be enough to pick up from the back column
    Of the machine off a 34" flat bed height? I have 8 foot forks also.
  1. Looking for Parts 1992 Citizen L20
    By RussellSt in forum CNC Swiss Screw Machines
    Last Post: 08-21-2013, 09:32 PM
  2. 1992 Haas vf-2 this is insane...
    By mikemike^3 in forum Haas Mills
    Last Post: 01-05-2012, 03:15 AM
  3. Fadal VMC 40 Questions (1992)
    By TMILLS in forum Fadal
    Last Post: 11-03-2009, 04:19 AM
  4. 1992 VF2 Inconsistant X
    By dafowfidy in forum Haas Mills
    Last Post: 03-31-2009, 03:21 AM
  5. Upgrading a 1992 32 MP control
    By chipsahoy in forum Fadal
    Last Post: 09-26-2007, 06:27 PM
