Are they coming up in the near future? Next summer? Never?
Thank You, Dave
Thank You, Dave
Dave,
The G380 will be coming out some time next year. We have been developing a custom surface mount breadboard so that development will go faster on all drives, and it is nearly finished. This means that development on the G201X, G380, G213V, and stepper-servo will resume.
Marcus
G380 update:
The G380 breadboard was brought-up for the first time today. Please see the attached .gif thumbnail:
The motor is a NEMA-34 servomotor. The yellow trace is the position error while the green trace is the motor current. The motor was caused to turn at 500 RPM while the direction was toggled every 500 milliseconds. The yellow trace shows the motor reversing direction and catching up with where it should be (+/-0.09 degrees) in 40 milliseconds. The scale is 26mV per increment of error. The green trace shows the motor drawing +/-19 Amps on direction reversal. Note the very clean waveforms; what makes them that way is the inclusion of a tunable integral coefficient (3 trimpots now for proportional, integral and derivative coefficients). The G320 integral coefficient is fixed and not adjustable.
The perceptible difference is there is no 'mushiness' when you try to turn a stopped motor by hand. The servo is very 'tight'; it resists instantly and there is no observable slight rotation and position restoration as with the G320. The servo lock range is a ridiculous +/-32,000 counts compared to the G320's +/-128. This may be pared-down to something more reasonable.
What worked today is the engine core; engine block, crankshaft, cylinders, pistons and valves. In the next several days all the promised G380 features will get added and be tested. They are the oil and water pumps, air-conditioning, and alternator in this analogy. Once they are running correctly, the G380 prototype board layout will begin.
What may fall out as a secondary product might be the G350 and G351; small-size, low power variants. Their size will be the same as the G250/G251 microstep drives. The price will be similar as well. The ratings may be 10A @ 50VDC; I don't know yet but that seems about right.
Mariss
Thanks for the update. Sounds great, when they are ready I will be buying them for my mill project. Dave
G380 update, the carry-on and eventual replacement for the G320:
A semi-major breakthrough today. How about a servodrive that is almost silent without any anti-dithering workarounds? The only sound you hear at any speed is the faint hiss of motor ball-bearings in their races and nothing else at all. Motor grunts and groans are totally absent.
I demonstrated my breadboard to our technicians today. The one that tests G320s thought it was a trick. He had to get eye-level with the motor to see it was turning at 1 RPM. Next he had to grab the motor shaft and see he could elicit a groan from the motor torquing it by hand. No dice; the motor was totally silent. Couldn't move it more than +/-0.18 degrees either; the scope was on it recording his efforts. Ran it 0 to 3,000 RPM and still silent. It was 6PM, all the production machines were off and the shop was silent. The only sound anyone heard was motor ball-bearings.
This will make Leadshine cry. We are no longer working for them as an unpaid R&D lab so no more DB810 (G320) next generation drives for them. They won't be able to pirate this drive.:-)
Mariss
Thanks you for continuing to develop great drives at great prices!
I hate to ask this question but, Do you have a ballpark idea when these will be available?
I am not going to hold you to an answer, just looking for a ballpark.
Thank you,
Cutmore
It will be soon. I have changed my design tactics from making prototype boards to using specially designed breadboards.
To stand any chance of success, a prototype board must be 95+% correct; they are not tolerant of major changes. On the other hand, a breadboard is meant for large changes because all the interconnects are hand-wired. I took some time out to design what for me are ideal breadboards; dual full bridges, two CPLDs, 16 op-amps and comparators, 200 0603 resistor/capacitor locations, 24 SOT-23s, opto-isolators, headers, trimpots, connectors, regulators, tactile switches, etc, etc. It's flexibility is beyond my expectations.
A dozen ways the G380 is different from a G320:
1) The servo lock range is +/-2,048 counts and it uses a 12-bit D to A converter (8-bit and +/-128 on the G320).
2) The power section is a current-mode amplifier (G320 is voltage mode).
3) All the PID coefficients are settable (P and D only on the G320).
4) The current limit is timed (defeatable), at 1 second for 20A, then drops back to the LIMIT trimpot setting (no more burned-up motors if run into a hard stop).
5) The bridge switching and current sensing has been redesigned to tolerate hard-stop motor crashes (no more popped drives when the motor is run into a hard-stop).
6) It has a built-in 1, 2, 5 and 10 encoder divider so it's like a G340 (the divider cannot be fooled like the G340).
7) The G380 is also totally silent (no servo "grunting" or audible step noise). It doesn't use "anti-dither" or dead-band tricks so there is much greater servo stiffness.
8) The STP/DIR optos are universal interface; you can put GND or +5V on COMMON without any header jumper settings.
9) There are 4 LED indicators, POWER, FAULT, WARN and INPOS. WARN lights when the motor is in current limit or when the following error is greater than +/-256 counts. INPOS (in position) lights when the following error is less than +/-2 counts and should help with selecting acceleration and velocity settings in the CNC program.
10) Short-circuit, temperature, reverse polarity and overvoltage protection.
11) ERR/RES separated into a FAULT output and RESET input or settable to ERR/RES as in the G320.
12) Optoisolated CH_A and CH_B encoder inputs. Use any encoders you want and power them from a single PC ground-referenced +5VDC supply.
For those that want a servo amplifier only, I'm looking at having a +/-10V input and a tach input.
The first version will be an exact fit and function replacement for the G320. It will not have items 11, 12 and the integral coefficient trimpot will not be accessible without removing the cover. That trimpot will have a factory default setting equal to the G320 hardwired setting. We're looking to do all of this at the G320 price.
Mariss
The common PWM interface is 'PWM' and 'DIR'. Because the G380 uses a CPLD, these signals could pass through the STP and DIR optos on a custom programmed G380.
Mariss
About current-mode amplifier, does it have adjustable gains as well? Those are usually necessary since amplifier behavior depends on motor resistance and inductance. With fixed gains some motors may have sluggis performance and in some cases the amplifier may become unstable.
Having built stepper systems around Gecko drives, including the G540, I'm pretty comfortable working with them. However I am new to the world of servo motors.
I have a 20 year old Omni-Turn CNC retrofit on a Hardinge lathe. At some point something is going to die, and I want to have a modern computer/controller in place before that happens. I could probably retrofit new DC motors, Gecko drives, computer & software for 1/2 the price of having the old controller repaired. Plus I would gain capability with new software, and have a system I can repair myself.
For this reason I'd like to see at some point a list of recommended motors for the G380. I guess specing the motor is not too hard, but I'm clueless about encoders.
Have a list of known good motor/encoder matches for the G380 would be a starting point for taking some of the guess work out.
Ed
Wow, I havnt even run a wire to my four new 320's I just got and now there already out of date. (nuts)I might have to downgrade them to my smaller mill and put servos on it instead of steppers so I can run these 380's on my big mill. The Low noise thing I believe I would enjoy, but a tighter driver for atleast the Z and the fourth axis would be nice.
No wander everyone always ends up with more than one CNC machine upgrades along will push you to having a few parts laying around. I have already upgrade several things and the machine hasnt even had voltage to it yet, LOL. I need to finish this thing befor something else comes up.
Jess
This sounds great, nice to see all the ideas and nice products over the years!!!
What kind off motors could we use for this drives, I`m looking for nema17
brushed servos. The only nice ones i can find are the ones from the company magmotors.
(they are like 250 dollars) cann people point me a company that makes nice cheap ones?
regards,
roy b
Veteq
I am running these motors on my mill with the G340 drives and they are working ok. It really depends on what your machine is and what you are trying to do. These use a Nema 23 mount pattern. I am running them at 24v currently so I am not even getting but about 70% of possible performance but the speeds and accuracy I am getting is great so I see no need to change.
http://www.cadcamcadcam.com/assemblymotorreducer.aspx
By the way the G340's are working great on my system.
AC
AC
Has anyone seen my pillow?
That are nice motors, but not suited for my apllication. I only have have room for nema 17 size and the reduction through a belt and pulley aint good for me, The reduction has backlash and the deviation error isn`t precise enough.
So , please suggest more direct drive nema17 brushed servo for me, if somebody knows!!!!
kind regards,
roy b
I guess I would recommend contacting a Globe Motor distributor as they make many small Brushed DC servo motors with US Digital encoders.
HTH
AC
AC
Hey Marcus,
My design is a small mill for aluminium and carbonfiber.
allready have the ground c3 preloaded ballscrews, rest on the way.
(10mm dia , 2mm / rev).
30.000 rpm spindle 125w
Stroke xyz is 100mm,
milling table is 120 x 110 mm.
maximum force when milling is 10 Newton, so thats almost nothing.
the axis are with linear bearing, so, almost no resistance.
masses:
y= 3,5 kg
x= 1,2 kg
z= 1,4 kg
max feedrate i would like to have 1000mm/min,
so thats 500 x 2, stepper speed for milling is 500rpm.
I would like to have high acceleration!!!!!!!!
and maybe higher rapids.
what will be your advice, would the linengineering stepper do?
nr. 4518L-07P with the G-540
http://www.linengineering.com/line/c...tors/4518.aspx
regards,
roy b.
why carbon fiber......don't get me wrong cool is good enough.
