Tauseef
OK, will try to take a crack at this based on the information that you have given plus some that I have done on the K2 site.
Given information:
Machine K2 3925
Servos 305 oz/in from K2 DGM 2800 rpm 50W 3.5A
Gecko 320s
10 amp 24 v power supply
2.10 Ghz 512 RAM computer.
Possible system information needed as gleaned from the K2 site and correct me if wrong:
Ball screws and I assume 5 TPI
2:1 reduction on the servo to ball screw.
OK, with a 24 V power supply, the maximum you will be able to turn the servo motor is 2800 rpm.
With a 2:1 reduction ratio, the lead screw will turn no more than (2800/2) 1400 rpm
A 5 tpi ball screw has a pitch of .2 inches so there fore, we are looking at .2 *1400, or a max of 280 ipm!
So far, absolutely no way to achieve 300 ipm! Now, according to Mr. Gecko himself, in a mail that he wrote to me:
“……… so even the smallest torque disturbance at deceleration is enough to overload the motor, causing it to fall behind the commanded location. This position error faults the drive.”
To prevent this problem, we should not run the motor at more than 80% of max rpm or in your case, .8* 2800 or 2240 rpm on the servo, eg 1120 at the lead screw or 224 ipm MAX! to get more speed, you either need to decrease the reduction ration (assuming the servo would still have enough power to move the system at cutting force), or change servo’s/ power supply.
Hope I have done my math properly:})
Art
AKA Country Bubba (Older Than Dirt)
