587,040 active members*
2,889 visitors online*
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Jan 2008
    14
    I need the Floppy Drive, as that's the only way to reinstall the system software after having a bubble/cmos memory replacement.
    However I have a chance to hold a Okuma Floppy Drive and took some photo on it.
    I did tried to replace the original floppy drive with off-the-shelf PC floppy drive. As the circuit board consist of simple components and layout. I also notice that the different of floppy drive is just the jumpers next to the input power socket.
    Any suggestion if I want to build another unit of this?
    Attached Thumbnails Attached Thumbnails IMG_0689.jpg   IMG_0693.jpg   IMG_0697.jpg   IMG_0698.jpg
  2. #22
    Mar 2009
    1982
    easy. Floppy drive must fit. Jumpers are for:
    1. 780kB capacity <-> 1,44MB capacity
    2. answer to "A" drive address <-> "B"
    sometimes could be more jumpers
    3. cable select
    4. write protection harware or soft type
    5. inversion of "drive select" signal
    6. inversion of "ready" signal
  3. #23
    Jan 2008
    14
    Nice... have you tried to build one of those? I believe I have to go back to the junk for the floppy drive.
  4. #24
    Oct 2006
    20
    We have a few of the floppy drives for CNC machines. Contact us direct at [email protected]
  5. #25
    Mar 2006
    45
    I don't know if this is of any help but: on my 700 control I once tried to copy a file with a name that began with the letter O. The control reported a floppy error but it was just that it didn't like the letter O.
    I pulled the drive at that time and looked at using a PC drive. In my opinion there is no way to convert a PC drive. The drive is Okuma right down to the printed circuit board and the electrical interface has no resemblance to a standard PC drive.
    Kev
  6. #26
    Oct 2006
    20
    Quote Originally Posted by calgarykevvy View Post
    Kev
    Hi Kev, send me a direct email to the email below and I can maybe help you out on your CNC floppy drive.
    MLD
    [email protected]
  7. #27
    Successfully working on Okuma
    Hi
    Great News !! We have tested our floppy to usb emulator to successfully work on below Okuma Models
    ( Okuma Crown Lathe L1060 with an OSP-U10L control, Okuma 700L 7000L U100M and E100M ) . Priced at US$95+shipping each ( includes 1 preformatted 4 gb Kingston Flash drive, One year swap warranty ) .
    Regards
    Vishal
  8. #28
    Aug 2012
    164
    We have replacement floppy drives (we can also repair your floppy drive) and we have the floppy to USB retrofit, which works great. My email: [email protected]
Page 2 of 2 12
  1. okuma lb15 spindle drive unit
    By TTT in forum Okuma
    Last Post: 02-03-2011, 03:49 PM
  2. OKUMA CROWN OSP 700L DRIVE UNIT
    By yorkshire grey in forum Servo Motors / Drives
    Last Post: 01-20-2010, 02:59 AM
  3. okuma LB15 spindle drive unit
    Last Post: 03-17-2008, 12:51 PM
  4. V2XT; Downloading from Floopy Disk ?
    By v488 in forum Bridgeport / Hardinge Mills
    Last Post: 01-02-2007, 06:25 AM
  5. boot floopy proble
    By bmfind in forum Commercial CNC Wood Routers
    Last Post: 03-22-2006, 12:28 AM
