Lathe Newbie here,
Is there a way in Mach3 to Home the lathe via a G-code program?
I have tried G23, G30 - unsuccessfully.
I would like to:
do a similar function as the "Set X Home", "Set Z Home in the Manual mode screens.
Then set X and Z to a particular value from the G-code....
(( this relates to another problem I am having getting the tool table to work sufficiently...))
Thanks for any help you can direct,
Joe
