586,069 active members*
3,757 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > What is the gcode to ref 1 axis home after
Results 1 to 7 of 7
    Mar 2007
    125
    i run a part? I want my x axis on my lathe to go to the home switch after every run of a part.
    thanks,
    Jul 2005
    12177
    G28 U0. should do it.
    Alternatively G53 X0.
    Mar 2007
    125
    g28 U(as in universe??) 0 (zero)?? I just tried that on my tormach and it did nothing. I didn't think about just sending it to absolute zero, duh, that's a great idea. I would have rather it actually depressed the switch and come back thereby homeing itself, but thiswill work. thanks,
    Apr 2005
    3634
    Turning
    "G28 U0" - means go home in X incrementally from the current location
    "G28 W0" - means the same for the Z direction
    Free DXF - vectorink.com
    Jul 2005
    12177
    Quote Originally Posted by seanreit View Post
    g28 U(as in universe??) 0 (zero)?? I just tried that on my tormach and it did nothing. ...
    I thought U was incremental X on a lathe.
    What happens if you just do G28 X? Normally this sends the machine to zero in the current work coordinate system then to machine zero (home). I do not like this because it can cause a crash as it moves to the zero before going home; this is the reason for using incremental because a zero in incrmental means no movement, it (should) just go home.
    I much prefer G53 because when you are using the machine coordinate ssystem you know exactly where it is going.
    Mar 2007
    125
    ya, i was running a part on the lathe so i just did the g28 on my mill. anyway, i went to mdi on mach3 turn and put in g28u0 and nothing happened at all.
    Mar 2007
    125
    g530 works perfect, should have thought of that before writing this, but thanks for the additional information on g28, I have not used that before, although in my case it's doing nothing, other than if i put g28 z homes.
  1. Replies: 15
    Last Post: 06-30-2016, 04:38 PM
  2. Eztrak X axis will not home
    By sidstover in forum Bridgeport / Hardinge Mills
    Last Post: 11-12-2008, 02:04 AM
  3. Z-axis 0 point (home) ?
    By tvdbon in forum DIY CNC Router Table Machines
    Last Post: 05-26-2008, 08:05 PM
  4. Z axis Home backoff
    By Stevie in forum Mach Mill
    Last Post: 12-21-2005, 12:28 AM
  5. Replies: 0
    Last Post: 03-10-2005, 07:46 PM
