586,069 active members*
3,303 visitors online*
IndustryArena Forum > CAM Software > Mastercam > how to import to from solidworks to mastercam
Results 1 to 17 of 17
    Mar 2008
    375
    hellow to all
    can someone please post anykind of part done in solidworks (something simple) top and botom to be machine.
    I am trying to learn how to import parts from solidworks to Mastercam then try to machine it and post it
    thanks
    Apr 2003
    3578
    For starters what version again of MC are you running this make the difference of what version of SW we give you.
    And for a second thought remember that what is top in SW is front in MC.
    So it might need to be reorientated the part that is.
    Cadcam
    Mar 2008
    375
    i am running mastercam x
    and for the second question
    (And for a second thought remember that what is top in SW is front in MC.
    So it might need to be reorientated the part that is. )
    I think I am just going to how to figure that out I have never done this before.
    thanks again
    Oct 2007
    153
    I found saving as and importing parasolid xt file format gave the least problems
    Dec 2008
    27
    I do all my designing in SW and all my CAM in MCX2.
    When I save my SW part I do it as a sldprt. When I open MC I click on the open icon, select the folder the part is saved to, at the bottom of the dialog box I select sldprt as file type, and then choose the model I am wanting to work on.
    Make sense???
    Dec 2008
    27
    I forgot to ask, have you downloaded the SolidWorks translator?
    Link to the page you need....
    http://www.mastercam.com/Support/Dow...2/Default.aspx
    57
    Import the solidworks file.
    That will be on level one
    open level two
    go to create, surfaces, from solid
    Then open level three
    go to create, curves, all edges
    now youhave the wireframe on level three, surfaces on level two and the solid on level one.
    This is a quote from PBMW on another forum
    Mar 2006
    1013
    Mastercam already reads SWorks file, You dont need to download any translator. It's already in there.
    File - Open - File Type - SLDPRT (Solidworks)
    Look at the "Options" button before opening the file.
    It will automatically create wireframe for you during import.
    If you have your EA Manager set in your defaults, it will sort out the wireframe and solids on to different levels (Bottom tray - Attributes - EA Mgr).
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Mar 2008
    375
    can you post ANY file from solidworks
    Mar 2006
    1013
    If you have Mastercam X1, go to Mcamx\Data\Translators\Solidworks if you just want to import any solidworks file.
    Mike Mattera
    Mar 2008
    375
    hey mike thanks I did figure it out the only thing was it only gave me a couple of option I was kind of looking for something like a square or rectangle that would have to be machined on more than one side
    thanks again
    Mar 2006
    1013
    It's not just wire frame, it's a solid. Hit Alt "S" to turn on shading.
    We machine top and bottom of a Solidworks file in this CD.
    http://www.tipsforcadcam.com/product/TFM-CDIntroX3
    Something to consider.
    Mike Mattera
    Nov 2006
    18
    Quote Originally Posted by Mike Mattera View Post
    That feature/function is version dependent in both directions.
    I find that the parasolid format is much less version dependent.
    May 2007
    71
    thanks
    Dec 2008
    22
    from solidworks use parasolid export
    i.e. *.X_T
    then it can be easy inported in mastercam
    there is solid and all curves in the imported file
    even you can generate the curves in the mastercam
    there
    Apr 2003
    3578
    Quote Originally Posted by DPKIF View Post
    I see a few postings say use Parasolid, this is of course one way.
    But as stated the issue with Version dependent is still there as there are different versions of Parasolid to. So also be aware of this if it does not work for you.
    Cadcam
    Apr 2009
    4
    You may save the file as a "parasolid" or iges or stp file.
    All these can be opened in MCam by selecting 'file type"
    I think iges is best for such transfers. It works with all versions of mastercam.
  1. Replies: 8
    Last Post: 11-17-2008, 08:18 PM
  2. SolidCAM & Solidworks vs. MasterCAM
    By griffithbuilt in forum Uncategorised CAM Discussion
    Last Post: 07-03-2007, 06:46 PM
  3. MasterCam or SolidWorks ?
    By cijunet in forum Mastercam
    Last Post: 12-19-2006, 09:24 PM
  4. solidworks/ Mastercam witch one !!!!
    By craftech in forum Mastercam
    Last Post: 01-16-2005, 05:11 PM
