586,546 active members*
3,337 visitors online*
Results 1 to 9 of 9
    Nov 2008
    214
    Small scale hobby hotwire CNC.
    Hi guys, I've been looking around the net for a easy and cheap built of hotwire CNC. I don't need anything huge or super fast, just something that can cut out wings and fuselage out of foam. By cheap I mean around $500 or less. I don't know if I sound crazy for wanting it that cheap, so please don't bash me... I'm new. So, let me hear what you have to say.
    Nov 2005
    12
    You could start by looking here:
    http://www.tron-cnc.de/cnc-styroporschneidanlage.html
    The page is in English
    Regards,
    Hugo
    Feb 2005
    15
    Another machine - a bit more expensive
    Looks like a very similar design
    http://www.foamlinx.com/fc2913.html
    Jan 2006
    11
    Well here you go! Go to www.drayconstruction.com or call 714-540-2279 and contact Danny. He has a set of plans just like the others shown, but all of the parts except the the electronics are available at your local hardware store. The plans include what to use for the hot wire power supply and what to use for the wire too. It looks like he uses it for making custom moldings. I also found some software at http://www.excelcut.netmyne.com/ (by the way it's FREE) should work to run the cutter. I down loaded an older version, but never got around to using it so I dont know how well it works so give it a try.
    Also check out this web site http://www.ae.uiuc.edu/m-selig/ads/coord_database.html as it has a listing of all the airfoils with there .DAT files that the software uses. Good luck on the build.
    Nov 2008
    214
    Woo, it seems that I would be able to build that after all. Thanks fellas! I'll post updates as soon as I decide on which one to build.
    Aug 2005
    578
    www.8linx.comfull instructions and hardware store bill of materials. great beginner site..
    Nov 2008
    214
    Thanks.
    Apr 2003
    32
    I have a foamlinx 29" machine for sale. Send me a Email
    Matneymodels at hughes dot net
    2 wrongs don't make a right
    But 2 Wrights makes a Airplane
    Kevin Matney
    www.Matneymodels.com
    734 - 848 - 8195
    "IN GOD WE 'TRUST "
    Feb 2009
    3
    If you really want cheap, and this thing should be more then stiff enough as well, check out here, http://grenadeindoor.modelisme.com/cnccompact.htm
    I intend to build a hot wire in the next couple of months of this design. I was all over the design at 8linx for awhile, but it's just way more machine then one needs to cut out airfoils.
  1. small-scale wood router work
    By GcoderD in forum WoodWorking Topics
    Last Post: 06-27-2008, 02:10 PM
  2. Small Scale Cannon
    By BAYWATCH-TIM in forum Hobby Discussion
    Last Post: 08-25-2007, 11:43 PM
  3. small scale
    By massbaster in forum Knee Vertical Mills
    Last Post: 07-03-2007, 03:02 AM
  4. Hobby milling machine - with a small budget
    By Siress in forum Uncategorised MetalWorking Machines
    Last Post: 02-27-2007, 11:12 AM
  5. Small scale RC chassis needed
    By Maxximum Attack in forum Employment Opportunity
    Last Post: 06-01-2006, 07:04 PM
