Originally Posted by
lsteele
....As I said (and I'm happy to be told I'm wrong) it seems like the cutters are melting the ali which sticks to them and so blunts them. As a rule of thumb does reducing the rpm mean more heat or less? (I would have thought less but since each flute's cutting more metal maybe more?)
Thanks again.
What tends to happen especially if the feed rate is too high and coolant/lubrication is inadequate is that chips get packed into the flutes then you get a mess because they rub, melt and the cutter breaks.
Always use two flute if possible to get better chip clearance. Keep the chipload below 0.0005" per tooth (0.01mm). With carbide you should be able to go at full rpm because the surface feet per minute is just over 600; carbide can cut aluminum at 3 times that. At 20000rpm your feed will be not more than 400mm/min.
But really the most important thing is adequate lubrication. You could try automatic transmission fluid (ATF) it works very well. Brush it on ahead of where the cut will be. Kerosene works well but is more of a fire hazard. Or see if your local Shell petrol station has ever heard of Shell Dromus B. This is a cutting fluid made by Shell for the last 80 or a 100 years ro so. It is mixed with water normally but works very well just brushed on neat.
