587,070 active members*
3,187 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > Considering Ramsond Super 200P TIG/Plasma Inverter
Results 1 to 18 of 18
    Jul 2008
    12
    This is also posted over at Welderzone, which I believe is the preferred venue for these questions, but since there is activity here, I thought I would give it a try.
    Have have several questions:
    1) Has anyone had any experience with Ramsond inverters?
    1a) If you have, did you have overheating problems with the 200P?
    2) I am a relatively inexperienced TIG welder (took the Lincoln Class) and have only used machines with HF start. The Ramsond is a scratch start machine. Any downside to scratch-start technique? Is it difficult to master?
    Please throw out any other considerations that you feel relevant regarding the purchase of a foreign-made inverter type welder.
    Much appreciated,
    Marc
    Feb 2006
    71
    Take a look at pirate4x4, I think there is someone on there that supplies chinky plasmas, with a guarantee and also uprated versions of them. I am not sure if he does welders but it would be likely.
    Jul 2008
    12
    Waiting for Ramsond
    Ramsond has a batch of re-engineered units coming online in the next few days. I will post the specifics of the unit which I am interested in.... once they post their new product spec's and links on the website.
    Another user asked me which machine I was interested in, generally I am interested in the Pulsed-TIG/Plasma/Arc machines.
    More next week. Thanks for everyone's advice.
    Jul 2008
    12
    Bought one
    I decided to go ahead and purchase one of their upgrade Super 250PY devices. They have problems if you plow through Aluminum all day long at max amp's.... but I won't be that person.
    http://www.ramsond.com/proddetail.php?prod=SUPER250PY&cat=9
    That's the link to the product.
    So, I will post my experience, as soon as I fire it up. Will start taking pictures when it arrives.
    Wish me luck!
    -Marc
    Jul 2008
    12
    Unboxed the Super 250py
    Well, the initial impression is that the packing was sufficient. The unit was double-packed; with one box contained in another box and surrounded by 1" of solid foam.
    The only down side to the packing: the bottom of the outer box wash not sufficiently taped. There was no intrusion into the inner box, so I signed for it.
    You can see what shipped, I took some photo's.
    Just pulled a 30-amp circuit off of my sub-panel and will fire it up tomorrow. Will blast through some steel and pulse-TIG some aluminum and post the results.
    One thing that I am disappointed about, they did not include collet's for anything larger than 1/16" tungstens (and the machine is 200amp). Not a big deal, but you think they would just throw it all in for convenience.
    Attached Thumbnails Attached Thumbnails DSC01073 (Medium).JPG   DSC01074 (Medium).JPG   DSC01075 (Medium).JPG   DSC01076 (Medium).JPG
    Jul 2008
    12
    Disappointed
    Well, guys. I am a little disappointed. A couple of problems with the unit, one major one minor.
    Major issue: The HF start is not functioning, so, no arc start on plasma torch :-(
    Major issue: The adjustment for gas pre-flow and gas post-flow on the don't seem to have any impact on the actual length of time for the pre- and -post flow.
    Minor issue: The "moisture drain cock" on the air flow regulator pops open and stays open each time the gas flow solenoid closes.... annoying and a waste of argon, to be sure.
    I have an email into the tech service people. Updates to follow.
    Jul 2008
    12
    It get's worse...... redux
    Now get this, the machine will not shut down. It remains running, even when the power switch is placed in the "off" position.
    It's not a "cooling off cycle", because I still activate the torch and the gas solenoid opens, while the switch is "off".
    I think I want to go throw up now. :drowning:
    Jul 2008
    12
    Requested a refund and an RMA number
    Well guys, I sent them this, on Monday:
    Chris:
    I pulled the cover off and you were correct. The spark gap was not set properly. After bringing them closer together, there is now a spark between the two points of the spark gap. However, no HF for any of the processes and no plasma stream.
    Also, the machine will not shut down. It remains running, even when the power switch is placed in the "off" position. I can even activate the torch, while the switch is "off".
    It looks like we have a very bad machine. I have to say that I have been very disappointed in the "out of the box" quality, at this point. I have had to modify components (e.g. shaving the rubber handles on the MMA and ground clamp connections), the plasma cutting function has never worked, there is no HF for AC tig or the Plasma functions, and the purge valve on the bottom of the regulator pops off every time the gas solenoid closes!
    At this point, I would like to return the device for a full refund. Can you send me an RMA number, please?
    Thanks,
    Marc
    No answer from them, either via email or phone..... very disappointing. Sent another email to their Sales Department, today. Hope they respond.
    Jul 2008
    12
    Finally
    After about a week of silence, they emailed me a RMA/return label. Thank goodness.
    This may be a unique experience among hundreds of satisfied customers, but I haven't seen anyone in any forum saying good things about Chinese-made inverters (with the one exception of someone saying they liked their Longevity unit). So, take it with a grain of salt and draw your own conclusions.
    As for me: Where did I put that number for Lincoln Electric or Miller???
    Feb 2009
    i tried to send you a PM, but it doesnt show in my sent box so I am assuming it is not working correctly for me.
    anyway, i also bought a ramsond welder, and would like to discuss my experience with you, but i'd rather not drag em through the mud on this forum.
    email me at [email protected]
    thanks,
    michael
    Feb 2009
    9
    Exclamation Chinese welders..every thing you wanted to know..
    I have just received the four welders/plasma cutters I bought from a Chinese company. They arrived quickly and I ma still testing them. They are a cut30 30 amp plasma, a CT416 small tig/plasma/stick and two large machines WSME-200 a combo machine and also a pulse combo called a Super 200P. You can find them under many different names on the web.
    The results so far.:
    Packaging OK very slight damage.
    The Cut30 works great on steel and aluminum has HF start and since this is my first experience with plasma I find it a great tool.
    The CT 416 worked fine both plasma tig and stick, no foot control but its a very tiny machine.
    The Super 200P has too many knobs,foot control and switches for me to understand without more work so I'll save my report on this and the WSME-200.
    General comment about workmanship especially the accessories, even when they are suppose dto be the same there were differences, like the air/gas connectors had different thread some taper seal and some O-ring seal..no good reason for this..
    My conclusion so far is to only buy from someone in the USA who will open the unit up check it out and then repack and ship to you with a 1 or 2 year guarantee.
    BTW I am an EE so minor problems will not bother me but easily broken or poorly made parts ( as reported in this thread ) do. One last thing the instruction manual is a joke.. why they can't ask an English speaking person to review the writing is also difficult to understand.
    Jun 2023
    Re: Finally
    I may be the lucky one but I have the SUPER250PY and everything about it works perfectly.
  1. Replies: 1
    Last Post: 06-16-2014, 08:15 AM
  2. prima plasma inverter pp35 for cnc
    By baldthreads in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-08-2012, 12:54 PM
  3. plasma cutter with arc inverter?
    By ata in forum Welding Brazing Soldering Sealing
    Last Post: 09-27-2007, 09:08 AM
  4. LG-30E Inverter Air Plasma Cutter
    By Estesg in forum Uncategorised MetalWorking Machines
    Last Post: 09-19-2006, 06:10 AM
  5. Anyone tried Super-Tech Plasma Cutter Kit?
    By muleworks in forum Waterjet General Topics
    Last Post: 11-29-2005, 06:10 AM
