586,104 active members*
3,310 visitors online*
Results 1 to 10 of 10
    Jul 2006
    1062
    Cheap Water-Proof Work Lamp
    I was considering milling a PCB to make a circular work lamp for my machine when I stumbled upon this on ebay For less than a tenner it seemed obvious I should buy one.
    Fully water-proof and very flexible (can be tied in a knot ) Perfick!
    Keith
    15362
    Hi Kipper
    As you can see in the photo the projected light is very poor & they only light the area were they are attached it's a great idea but you won't get much light on the job or cutter
    Mactec54
    Jul 2006
    1062
    Hi Kipper
    Maybe if I use my camera later...instead of the camera phone.....
    Keith
    Machine tool worklights
    Kipper,
    Check www.cncsolutionsllc.com Supplier of waterproof machine lights.
    --Solute
    Jul 2006
    1062
    Quote Originally Posted by CNC Solute View Post
    Kipper,
    --Solute
    Yeah I had a look....I don't see anything but modified pond lights and torches (flashlights for the US cousins) they all cast shadows! 47 10.000 MCD Leds are quite illuminating.
    I'll have to get David Bailey to take some pictures of the brightness as it phases my ancient camera.
    Keith
    Aug 2008
    573
    Great idea Kipper, I've just added one to my machine
    The spead of light is actually very good, it only casts a cone shaped shadow for a couple of inches directly below the chuck (see attached).
    I clamped mine in place with a ally band.
    I was wondering about strobing the LEDs to 'freeze' the cutting action?
    Freezing motion is not normally a good idea for obvious safety reasons, but a button activated option for inspection purposes might be useful.
    What do you think? Anyone tried this?
    Attached Thumbnails Attached Thumbnails LED light a.jpg   LED light clamp.jpg   LED light shadow.jpg
    Jul 2006
    1062
    Nice one Bill! :cheers: I don't use a collet chuck and hadn't thought about the cone shaped shadow. I'm going to be making my casting for the Z axis conversion over the holidays and will incorporate the led light into it along with air and coolant (if I get all the jobs for other people finished) 4 birds with one stone
    Tell me if it's better than spending £50 on a vertex worklamp that always needs repositioning
    Keith
    Jul 2006
    1062
    Not sure about the strobing light....Might be fun
    Keith
    Aug 2008
    573
    I don't know if it's just me, but I find spot type lamps always seem to produce a bright specular reflection that actually make see harder to see what's going on.
    And the noobs shall inherit the earth!
    Are the tadpoles all at sea now?
    Jul 2006
    1062
    Quote Originally Posted by BillTodd View Post
    I agree on the spotlamp Bill :yes:
    All the tadpoles drowned.....Doing deflection calculations on 12mm unsupported rod.....
    Keith
  1. GE 388 Lamp
    By lgreeves in forum Fanuc
    Last Post: 02-01-2010, 08:20 PM
  2. RFQ - for water jet work
    By jimalb in forum Employment Opportunity
    Last Post: 04-16-2008, 01:58 PM
  3. Hypertherm PowerMax1000 and Water Table won't work?
    By barnon in forum Waterjet General Topics
    Last Post: 12-12-2007, 04:51 PM
  4. Could this work as a cheap power supply?
    By phantomcow2 in forum CNC Machine Related Electronics
    Last Post: 03-05-2006, 11:10 PM
  5. Why won't cheap servos work?
    By Ubarch in forum Servo Motors / Drives
    Last Post: 02-08-2005, 08:39 PM
