586,094 active members*
4,206 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > DIY 4th axis: Shaft size conversion?
    May 2008
    43
    I picked up a harmonic drive+housing+motor from ebay that used to be part of an Epson SCARA robot. The drive is nice, but it is driven by an AC servo motor and I don't really want to use it.
    What I'd like to do is replace that motor with a simple stepper motor. The problem is that the mount isn't NEMA. The shaft diameter needs to be 14mm.
    Does anyone sell a simple "shaft converter" that I can slip on a 1/4" NEMA23 stepper to give it a 14mm shaft size?
    I don't have access to a lathe or I would just make my own... =/
    Jan 2007
    634
    Try sdp-si.com, they have a variety of exactly what you need including metric/inch converter sleeves. I've used items from them to do the exact same thing. You'll love a harmonic drive as a rotary axis, BTW.
  1. sherline mill conversion. what size steppers
    By wedge in forum Benchtop Machines
    Last Post: 03-18-2008, 03:27 AM
  2. what size shaft...........
    By Taylorm in forum MetalWork Discussion
    Last Post: 10-21-2007, 04:31 AM
  3. KL34H2160-62-8B stepper motor / drw dual shaft size ?
    By harryn in forum Automation Technology Products
    Last Post: 08-17-2007, 07:51 PM
  4. Z axis shaft material
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 05-16-2005, 01:46 PM
  5. shaft size
    By smarbaga in forum Mechanical Calculations/Engineering Design
    Last Post: 04-20-2005, 03:39 AM
