586,119 active members*
3,420 visitors online*
Results 1 to 11 of 11
    Apr 2008
    4
    mitutoyo linear scale pinout
    does anyone have a diagram of mitutoyo linear scale (model AT112-one side is 9 pins round plug and the other is D connector 15 pins. )? I have it on my bridgeport and the cable is broken when it moved to my garage. thank you .
    Feb 2010
    Need Help! mitutoyo linear scale pinout
    Did you ever get an answer, as I have a similar problem?
    Feb 2008
    69
    I have got them here somewhere, I will find them over the next few days and post it up for you.
    Dave
    Nov 2016
    14
    Re: mitutoyo linear scale pinout
    Quote Originally Posted by Davo J View Post
    Dave
    I am running into the same problem : could you please post any information on this topic please?
    Feb 2008
    69
    I do my best to get a picture today
    Sent from my 5056I using Tapatalk
    Nov 2016
    14
    Thank you very much in advance!!!
    Feb 2008
    69
    Thanks for the reminder, I had forgotten.
    I have the manual on these scales, and a lot of others, here are the pin outs.
    If you need any more or other info let me know.
    Dave
    Nov 2016
    14
    This is the actual connector:
    Attached Thumbnails Attached Thumbnails RM15WTRZB-8P(71).jpg   Mitutoyo Linear Scale_1.JPG
    Feb 2008
    69
    So it's 8 pin? How many wires are connected to it?
    Also what scale number is it?
    Nov 2016
    14
    yes exactkt the 8 pin connector,
    attached are the following colors:
    red
    orange
    yellow
    blue
    green
    brown
    it is a AT112 scale\\I started a special thread for this : http://www.cnczone.com/forums/genera...at112-one.html
    Thanks!
    Apr 2021
    Thanks to Davo J I have found the colour codes for the Mitutoyo AT2-N scale. We had a cable with the same colours as SparkyNL with a round 6 pin plug pulled off. We sacrificed a connector from the scale on an unusable lathe in order to find which wire came off which pin. However, the wires in this cable were black, brown, red, orange and yellow. I buzzed these through to the connector pins and found they followed the resistor colour code, in that brown -1, red - 2, orange - 3, yellow - 4 and the exception black - 5.
    Our readout has 9 pin D-type connectors so I had an adaptor cable from 6 pin round. Using this to find which pins of the D-type were connected to the 5 wires, I found the yellow wire was not connected. This left brown red orange and black - which from Davo J's list of signals is +5V, A, B and 0V which made sense! As there was no black in the cable I needed to connect, it made sense that they also followed the resistor colour code but used green - 5 for the 0V. I wired these to the D-type pins I'd found from the adaptor cable and sacrificed plug and the readout (z axis) was back!
    For completeness the 4 wires connected to the D-type are: brown (+5V) - 7, red (A) - 6, orange (B) - 8 and green (0V) - 2.
  1. Mitutoyo AT116 linear scale
    By braco in forum Uncategorised MetalWorking Machines
    Last Post: 12-18-2017, 03:47 PM
  2. mitutoyo scale a11-n wires pulled
    By speedchaser in forum CNC Machine Related Electronics
    Last Post: 10-30-2012, 02:34 PM
  3. Sargon DRO & Mitutoyo AT715-750 Scale
    By ynnek in forum CNC Machine Related Electronics
    Last Post: 08-02-2009, 04:30 PM
  4. mitutoyo linear scale cable pinout
    By pham1129 in forum Uncategorised MetalWorking Machines
    Last Post: 12-08-2008, 02:25 PM
  5. IH Kit & Linear Scale
    By SMW Precision in forum Charter Oak Automation Support Forum
    Last Post: 04-17-2006, 11:18 PM
