586,047 active members*
3,720 visitors online*
    Mar 2007
    215
    SuperMax Max 3 Tool Change Problem
    Hi guys, a CNC mill in our shop, a SuperMax Max 3, is not changing tools properly. The cassettes on the carousel are crashing into the tool holders when grabbing tools out of the spindle. The carousel indexes fine and it will pick up tools OK. M19 (spindle orient) is working fine as well. No alarms are occurring, the carousel moves into the tool holder under the head and crashes and locks up. It seems the position of the carousel is low in relation to the tool holder placement on the z axis. The bushings and bearings in the carousel were replaced within the last year, also. Any suggestions or thoughts?
    Joe
    Mar 2007
    215
    Problem solved, kind of. Had to change Z axis grid shift (para 510) however now we are getting an alarm that says spindle is too low for a tool change, when it is clearly not. Any ideas how to get past this?
    (Moderator, I'm sure this is in the wrong forum.)
    Re: SuperMax Max 3 Tool Change Problem
    Quote Originally Posted by Crashmaster View Post
    Hi. I'm having the same problem. Do you remember how your carousel was adjusted? mine needs to go up about 1/32", or Z home position needs to come down with that 510 parameter. Wont go any lower with the param.
    We also replaced the roller bearings.
  1. VMC 760/16 Tool Change Problem
    By Harmeet in forum Bridgeport / Hardinge Mills
    Last Post: 04-07-2013, 12:12 PM
  2. Tool Change Problem
    By el_maquinista in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-30-2011, 05:33 AM
  3. bp vmc 760/22 tool change problem
    By laserh20 in forum Bridgeport / Hardinge Mills
    Last Post: 07-01-2010, 03:19 PM
  4. Tool change problem.
    By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-12-2010, 11:46 AM
  5. VF3 tool change problem
    By cata1351 in forum Haas Mills
    Last Post: 10-19-2007, 12:11 AM
