Hello guys
I have made a 3 axis cnc controller based on TOSHIBA TA8435H ICs.
It works perfectly at low speeds. for example when I set Mach3 like below settings, there is no problem and the motors spin without losing steps (but slowly!).
Steps per mm : 1800
Velocity: 100
Acceleration 20
Slow jog rate : 25
It's so slow and takes minutes to move the machine for 20cm.
But as I set a higher speed, the motors make a high pitch noise, jerk with high frequency ( like they want to spin fast but they can't) and they don't spin.
Here is the complete specifications of the stepper motors I'm using:
Model: 42BYGH023 (Bipolar , 4 wires)
Step angle: 1.8
Voltage: 12v
Current: 0.4A
Holding Torque: 2100 g/cm
Detent torque: <220 g/cm
Rotation inertia: 20 g/cm2
Power supply : 12v 8.5A switching
can anyone tell me what is wrong? the motors are not powerful enough to handle higher speeds?
and Why when I click on "GOTO Z" in Mach3 software, it ignores the motor tuning settings and makes the motors spin at high speed? so my machine can't handle that speed and starts jerking!
Thank you
