587,047 active members*
2,695 visitors online*
    Oct 2006
    143
    Leveling a Lagun Vertical Mill
    I've got a couple FTV-2S vertical mills that I need to level. I haven't done this in years but it seems to me we made a plate with a tapped hole and a lip (to keep it from rotating) to catch the edge of the machine. Then we used threaded rod as a jack screw to level them with a nut and washer on top to lock it in place. Does that sound right?
    Any better suggestions, other than the $100.00 a set wedges?
    Don
    Aug 2005
    1622
    For a typical knee mill it is not that critical. With a gaged variety of 4x4inch square pieces of sheetmetal, shimming the corners does the job just fine. As long as it doesn't rock, true level shouldn't be a problem.
    DC
    Sep 2008
    73
    Sheet metal shims work great. I like a machine level it just takes one more variable out.
    Sometimes I need to use a level for a quick setup. If the machine is not level the set up will take a little longer.
    Evan
  1. Lagun mill powered knee
    By jjclear in forum Knee Vertical Mills
    Last Post: 12-03-2008, 08:29 PM
  2. Go-Well vertical mill
    By Matt130 in forum Benchtop Machines
    Last Post: 08-14-2008, 08:09 PM
  3. Lagun Mill (BP clone) CNC conversion How To?
    By Kerry Harrison in forum Bridgeport / Hardinge Mills
    Last Post: 08-24-2007, 06:23 PM
  4. Lagun Mill (BP clone) CNC conversion How To?
    By Kerry Harrison in forum Stepper Motors / Drives
    Last Post: 08-21-2007, 01:31 AM
  5. Best Vertical Mill?
    By bvandenb in forum Haas Mills
    Last Post: 04-20-2005, 11:47 AM
