586,666 active members*
3,566 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How do I set solid stock properly on this file?
    Dec 2008
    7
    Why does tool cut air when using solid simulation on this file? Please tell me what I am doing wrong. Using Mastercam X3 with latest maintaince update.
    Attached Files Attached Files
    Dec 2008
    7
    Might be close to figuring this one out. I think I need to add stock for the .015 I am leaving on the drive surfaces for roughing this part out. Is the place to do this in the "stock setup", "stock origin Z box" by typing it in and adding .015 to the Z or is the better way just adding it to a bounding box i almost always create for my 2d mill parts?
    Mar 2006
    1013
    Roughing parameters - Cut depths - Adjustment to the Top Cut
    put in a value for how much extra you want to take for the 1st top cut.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
  1. DWG from a solid file
    By cijunet in forum Solidworks
    Last Post: 05-09-2008, 11:48 PM
  2. Picking stock in solid machinist turn
    By inflateable in forum EdgeCam
    Last Post: 03-17-2008, 04:37 PM
  3. Solid Model CAD file(s) of HF 44991 / X2 Mini Mill?
    By blades in forum Benchtop Machines
    Last Post: 12-27-2007, 01:05 AM
  4. Replies: 11
    Last Post: 12-18-2007, 09:02 PM
