Hello all,
I have a new syil america x2 that I took delivery of a few weeks ago. I've gone over the machine and tightened up all of the loose screws and wires I found. I've also tweaked the mach3 configuration to be in the ballpark of where I think it should be for this machine.
The problem I am having at this time is one of accuracy. Specifically, I want to cut a pocket 1" from the edge of my fixture. After setting up the machine and cutting the pocket I find that the pocket position is off by .015" (actual position 1.015") so it is moving further than it should.
I initially was using a mechanical edge finder. After seeing some of the threads here on probing I set that up but ended up with the same results.
I've checked my motor settings, backlash settings, G code, cutter diameter, gib adjustment, etc and can't find anything out of whack. The computer is running xp and was purpose built for this application, it is stripped of all extraneous applications.
I've also replaced the original mechanical limit switches with prox switches in hopes of eliminating any home switch repeatability issues.
Not sure what to check next.
Thanks for any input
Bob
