586,281 active members*
3,776 visitors online*
    Jan 2007
    118
    MAZAK SLANT TURN-28
    HELLOW FRIENDS,WE HAVE RECENTLY PURCHASED A MACHINE MAZAK SLANT TURN 28 WITH MAZATROL CAM T3 CONTROLLER BUT THE MACHINE HAS COME WITHOUT ANY HARD COPIES OF THE NECESSARY PARAMETERS AND MANUALS.THE PROBLEM IS WHEN WE SWITCH ON SOME OF THE PARAMETERS SEEMS TO BE CLEARED AND LOOKS LIKE WE MAY HAVE TO GO FOR INITIALISING THE SYSTEM WITH FRESH NEW PARAMETERS.WHAT IS THERELEVENT MAZAK MANUAL.IS THERE ANY PROCEDURE AVAILABLE FOR THIS. HOW ABOUT THE PLC LOGIC? IS THERE ANY POSSIBILTY OF THE PLC ALSO GOT ERASED.HOW DO WE CHECK ALL THESE?WE ARE NEW TO THIS MAZAK OLD STUFF.HELP PLEASECHANDRU
    Jan 2008
    65
    sounds like you have to do a control re-initialization. this happens when the power is off for some time and the battery has failed. i have a copy of the procedure if you need one. send me private message with your email address and i will send it to you. you will have to be sure that you have a copy off the parameters somewhere. most the time a hard copy is found in the slot of one of the control cabinet doors.
    Jan 2008
    65
    Quote Originally Posted by CHANDRU View Post
    check your email
    Apr 2010
    Hello Friend ,
    Do you have Parameter for Mazak Slant Turn 30 Universal 1500 with Mazatrol T1.
    I loss the Parameter and Loaded with QT10 Parameter but the Turret can not work Properly and the Gear Shift also have a Problem if I loaded the Parameter QT10 to Slant Turn 30.
    I am sure has a different Parameter for Slant Turn 30 and QT10
    Please help me
    Apr 2010
    Hello Friend ,
    Thank you so much for your respon.
    The Problem is the Turret Can not Index if I change the SQ Parameter the Turret can Index but the gear shift can not working Properly I am sure have a Parameter not match with my Slant Turn 30.
    Now I loaded the Parameter QT10 due to I dont have the Slant Turn 30 Parameter .
    Please send me through my email your slant turn 28 Parameter I hope it will work.
    [email protected]
    MAZATROL T1
    Servo Drive : VALUTROL 6V30F3389
    NC System : MELDAS YL
    Controll Unit : UL52C
    Servo X Axis : TRA 41
    Servo Z Axis : TRA 61
    Thank You,
  1. Need help with Mazak Slant Turn 15 Univ. / Mazatrol T1'
    By Haaatschi in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2021, 01:33 PM
  2. Need 6T Fanuc Manuals of Mazak Slant Turn 15 Universal 1000
    By Donatello Tam in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-07-2010, 12:51 PM
  3. MAZAK SLANT 15
    By MPIMOTORS in forum Controller & Computer Solutions
    Last Post: 07-14-2008, 11:57 AM
  4. Mazak Slant 80 with T2
    By LTS in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-21-2008, 03:38 PM
  5. mazak slant turn 40n
    By intermax in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-04-2007, 09:16 AM
