586,121 active members*
3,156 visitors online*
Thread: Haas monitor
Page 1 of 2 12
Results 1 to 20 of 24
    Sep 2008
    12
    Haas monitor
    I need a monitor for a Haas VF-5, 98 or 99 model. 12", 9 pin #93-5220c.
    Tim
    Aug 2008
    15
    Sep 2008
    12
    Aleady ordered a new one from Haas... Thanks for the contact...will be useful in the future.
    Tim
    Are these LCD conversions? Plug and play or is there more to it?
    Was about to order one from Haas but would upgrade to something nicer/less expensive if possible.
    Mar 2010
    1852
    Quote Originally Posted by Scatstroker View Post
    The post was 4 years old!
    Quote Originally Posted by Machineit View Post
    I understand that but if converting to an LCD was the answer then I don't see how it would be any different now?
    Is there any updated information available for this?
    Nov 2012
    LCD replacement for Haas CRT on VF3
    We installed and have working a LCD replacement on a Haas VF3 this weekend and it appears to be working fine.
    We are making a bezel to install the monitor.
    Here are two videos of the monitor in action:
    LCD Video #1
    LCD Video #2
    Photo#1
    Photo #2
    More information to come as we get it.
    DL Hodgdon
    H. H. Mercer, Inc.
    H. H. Mercer, Inc. Machine Shop Birchwood Casey hhmercer
    I'm assuming it wasn't quite plug and play? Can you describe what was needed? I would assume its a different plug set but I haven't seen any documentation on it.
    Would you be interested in making a second bezel if it turns out nice?
    Thank you.
    Nov 2012
    LCD replacement
    It was plug and play.
    Removed old CRT plugged 9 pin DIN connector in and powered up.
    The LCD has a board in it that accepts the old signals.
    The bezel has all ready been designed and I hopefully will get the master cam programs in the next day or so.
    There is another post on this forum that shows the bezel.
    As soon as I get all the information together I will post it.
    Haas is coming to look at our installation today.
    Will have word from them also after they visit.
    DL Hodgdon
    H. H. Mercer, Inc.
    So literally as simple as purchasing a $100 LCD from anywhere and plugging it in? The original lists as 12", yours appears larger, does it mount in the same area with the bezel?
    Please excuse the ignorance but I have my first Haas coming and it needs a CRT, I was going to order it but I'd rather have an LCD and for 1/5 of the price I really don't see the downside.
    Thank you.
    Nov 2012
    Not your standard LCD
    Yes and No
    No it is not your standard LCD.
    The LCD is a 12.5 inch LCD measured diagonally.
    The LCD has special circuitry in it that will accept the older video signals.
    Remember when monitors were EGA and the old twinax bank monitors?
    These new LCD monitors are built to accept the older inputs. The paperwork that came with this monitor said it would accept 9 different older video signal standards.
    Yes - the monitor was plug and play.
    Paid for it and bought on Friday.
    Opened console on Monday and unplugged CRT
    Plugged in LCD and powered up it worked instantly.
    The only thing I had to do was allow the monitor to "Auto" adjust and the picture came in and positioned itself just fine.
    I did adjust the color temperature and allowed it to "Auto" correct.
    We have been working on trying to get all the information together and will post here in the next few days.
    We are very happy not to be using the CRT anymore.
    DL Hodgdon
    H. H. Mercer, Inc.
    Nov 2012
    More Photos of our LCD conversion from CRT
    This conversion was done a Haas VF3 that had a failed CRT
    Removed old CRT.
    *** NOTE - DANGER - Warning Will Robinson !!!!!!!!
    MAKE SURE YOU DISCHARGE THE FLYBACK AND CAPS ON THE CRT BEFORE DISASSEMBLY.
    GOOGLE CRT HIGH VOLTAGE TO SEE HOW TO DO THIS.
    *** Take this warning seriously less you wet your pants and learn what a defibulator feels like.
    Be careful to not break the CRT iteself.
    EVERYTHING can be unscrewed and the whole CRT assembly can be seperated from the frame.
    Removed CRT and all CRT electronics from CAD plated CRT Frame.
    We saved the CRT and electronics in case we needed them.
    LCD has a normal screen on it and is not protected from the elements.
    We made our own screen protector.
    Made a sacraficial lens/screen protector from 0.093" acrylic.
    Cut screen protector on laser.
    Put 0.093" holes in screen protector to allow a pencile to pass through so that the operator could press the monitor buttons on the face of the monitor.
    Burned these through with the CO2 laser.
    Made a backing plate out of the old monitor bracket.
    Made some aluminum stand offs.
    Threaded both ends of stand offs.
    Placed screen protector against panel face.
    Used stand offs to screw screen protector to panel face.
    Put monitor against screen protector.
    Shimmed the face of the monitor to keep screen protector from pressing function buttons on LCD.
    Put backing plate on outside of monitor and sandwitched everything together.
    Plugged in 12v power supply to 110VAC power cord in cabinet
    Plugged in 9 pin DIN connector and extension cable to 9 pin DIN video supply.
    Powered on monitor and machine.
    Set monitor using auto adjustments
    Put Cover back on machine
    Make parts.
    DL Hodgdon
    Feb 2010
    1184
    Quote Originally Posted by tagtech View Post
    Yes and No
    DL Hodgdon
    H. H. Mercer, Inc.
    So what was the monitor that you used?
    Price?
    Purchased from?
    End result looks great, nice job!
    Dec 2012
    Monitor Info
    Thanks for posting about our monitor tagtech! I hope everything is working well with it. This is a monitor we worked in conjunction with a Chinese company to design and manufacture. It does Mono TTL, CGA and EGA video using the original 9 pin video cable with an LCD screen. It is still not a perfect solution because it cannot cover the entire frequency range of all the possible monitors out there but we have a 90% success rate using it to replace Mono TTL CNC monitors. We understand that when your CNC machines go down that you are losing money so we offer same day shipping all the way till 6PM Central time and for an additional fee will even come into work and ship on a Saturday. 30 day warranty to send it back if it doesn't work for your needs or to get a replacement. No restocking fees, we only ask you pay for shipping both ways (return shipping can be as cheap and slow as is necessary for you).
    Monitor part #: C1212ttlcgeg
    Price: $429
    Purchased from computerfusion.net
    Phone #: 817-354-4446 or 1-800-426-0089
    Photo pages:
    Mono: New Monochrome TTL Monitor
    CGA: # C1212TTLCG
    EGA: New Color Graphics Adapter, CGA Monitor
    for weekend orders, buy through ebay and send a message to have it shipped out that day: New 9pin Monochrome Monitor Mono TTL MDA HGC HGA MGP | eBay
    Video of it working: https://www.youtube.com/watch?v=XEphkEQPvhY
    Dec 2012
    LCD monitors
    cfusion really works with the end user to solve their CRT issues. I personally fell into the 10% that they can not cover my frequency. They sent me a 2nd monitor to try and also an actual CRT. The CRT worked but could not get the LCD's to work on my particular 1993 Haas VF0. I have to send them back and absorb the shipping, but I guess that is cheaper than having a tech show up at 100.00+ per hour.
    May 2012
    17
    Re: Haas monitor
    LCD Monitor for HAAS CNC machine
    Also for Fadal CNC88, CNC88HS, Fanuc 8" monochrome and more
    - - - Updated - - -
    http://monitorexperts.com/en/lcd-monitor-for-haas-cnc-machine.html
    May 2012
    17
    May 2012
    17
    Re: Haas monitor
    Seems a lot of sales effort with no posted prices. Only a "contact us" or phone number. How much is it?
    Feb 2009
    311
    Re: Haas monitor
    Quote Originally Posted by Zahnrad Kopf View Post
    This sort of thing annoys me to no end! It is ridiculously easy (and cheap) these days to setup a simple e-commerce site where you can show off and sell your stuff. People are so much more likely to buy from you if you make it easy and are up front with all the information, including price and shipping.
    C|
Page 1 of 2 12
  1. LCD Monitor
    By Dyad1 in forum Fadal
    Last Post: 06-25-2022, 07:20 AM
  2. Replace old CRT monitor to LCD monitor
    By =aike= in forum Okuma
    Last Post: 01-16-2020, 08:29 AM
  3. Replacing a Haas Monitor
    By Depth_of_cut in forum Haas Mills
    Last Post: 12-16-2019, 04:21 AM
  4. Haas monitor
    By murphdog in forum Haas Mills
    Last Post: 01-11-2015, 01:40 PM
  5. 1990 Haas VF1 video monitor fuzz
    By ChuckMTB in forum Haas Mills
    Last Post: 03-26-2011, 06:49 PM
