586,728 active members*
2,754 visitors online*
Thread: battery alm
    Jul 2006
    5
    Thumbs up battery alm
    I have a fanuc om control on my machineing center. The screen shows a BAT alarm on it. I have change the 3 d size batteries in it. 3 different brands and clean the contacts, and measure the voltage on the batteries themself and on the cable going to the board. They all measure good. Is there some where else to look? I also backup the parameters, but not anything else, the manual i have dose not tell about backing up the diagnois,etc.
    Jul 2007
    38
    We have some newer lathes that have batteries on the back of the operator screen and the keyboard, if it is a fanuc check the servo amps also because they have batteries too. One other thing to check (don't laugh or get mad) did you install the batteries in the right direction? Only reason I ask is because I've done that in the past and didn't realize it until after I lost all the parameters
    Jul 2006
    5
    Yes i did 4 times not mad at the answer, you can turn the batteries around.
    Where on the sevro would the battery be? The controls are 1992 model. What would the batteries look like , watch battery size, e-prom stlye, ect.
    May 2005
    109
    Quote Originally Posted by Drye-123 View Post
    To punch out diagnostic: in edit mode + diag screen --> Output Start
    In Fanuc O PMC data are registered in diagnostic so you have to backup if your machine have PMC data.
    If your machine is using absolute encoder, there must be another 4 batteries case. Replace these batteries also.
    Jul 2007
    38
    On our machines the servo batteries on on the front of the servo amplifier, there should be a rectangular cover that will stick out and have 2 wires that plug into the front of the amplifier. The battery configuration could be 1 of several styles ranging from a single 3 or 6v (about the size of a AA battery) to a pack of 4 that are shrink wrapped together. If all else fails call fanuc, I've had a fair amount of luck with them over the phone
  1. Battery balancing
    By CamEllis in forum CNC Machine Related Electronics
    Last Post: 12-04-2007, 08:50 AM
  2. CPU dead battery
    By LT1TRUCK in forum Computers / Desktops / Networking
    Last Post: 09-10-2007, 12:47 PM
  3. Battery Replacement
    By lovell110 in forum Haas Mills
    Last Post: 08-10-2007, 06:20 PM
  4. Upc Battery & Zero Return
    By Jedi in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-20-2007, 03:44 PM
  5. Battery Power!!
    By JavaDog in forum CNC Machine Related Electronics
    Last Post: 06-16-2005, 09:20 PM
