586,080 active members*
3,655 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > power supply required for 4 axis system
    46
    hi,
    I am willing to go for a gecko G201 4 axis system (X axis with 2 steppers).
    I would like your advise on 3 things:
    1 - can I use 2 power supplies (one for 2 motors)
    2 - if I use only one supply which capacity it shall have knowing that I want to achieve high torque at high speed because my machine gantry is heavy (30-40kg). I beleive I will use steppers parallel connected.
    3- Am I missing something to run the system?
    here are the details of what I may intent to use:
    - steppers:
    860 oz. in.motor for Z axis
    then for X and Y, 3 steppers: No. of wires=4, Bipolar Volts= 3.0, Amps=6.0, Ohms=0.5, Holding torque=8.5Nm. 0r 1200 oz-in
    - breackout board:
    CNC4PC C1G parallel port interface
    - 4pcs G201 drives
    - Power supply:
    big question...
    http://cgi.ebay.com/48V-11A-400W-Pow...742.m153.l1262
    see my questions above...
    if you'd like to see my machine (currently running on Xylotex):
    http://www.raptor-rc.com/cnc.htm
    thanking you in advance for your advises.
    About 16-20 amps, and for voltage, use 32 x sq rt of the motors inductance.
    46
    Lightbulb supply?
    so I beleive that I need only one power supply as shown on the web link. is it?
  1. Unipolar Motors, Power Supply, and 3 Axis Controller
    By Nightwork in forum Stepper Motors / Drives
    Last Post: 12-07-2007, 01:04 AM
  2. Help w/ power supply for a 3-axis servo system
    By yantra3d in forum CNC Machine Related Electronics
    Last Post: 07-25-2007, 08:41 PM
  3. Compressed air supply required for 50A plasma..
    By hotponyshoes in forum Waterjet General Topics
    Last Post: 04-15-2007, 02:16 PM
  4. 4-axis and Contorler questions and power supply
    By wakeboard in forum DIY CNC Router Table Machines
    Last Post: 01-14-2004, 12:40 AM
  5. Replies: 8
    Last Post: 11-05-2003, 10:39 PM
