Equipment:
Motors: Two IDC S21T wired in series
Drive: IDC S6002 (Dual Axis Microstep Drive)
Indexer: IDC 961 (Single axis indexer)
Motors are mounted vertically.
| 1 | (spins CW)
| 2 | (spins CCW)
Issue:
I power up the machine, then run a homing program. Both motors move about 1/4 normal speed during the homing process. Then I run my standard program and motor one spins the wrong direction (CCW). I've found that if I just let the machine sit for about 20-30 minutes then try to home/run it operates normally.
Any ideas on the "warmup" issue?
