586,108 active members*
3,100 visitors online*
Results 1 to 8 of 8
    May 2003
    550
    cad models for common parts.
    Hi all..
    Does anyone have or can point me to a source for cad models for some of the common parts we use? Porter Cable or other Routers, steppers, couplers, bearings, ballscrews etc? Either in 2d or 3d, dwg, dxf, stp etc..
    I'm starting a new machine and doing it in cad (autocad) first, 36"x36"x9" and using 80/20 for the frame and drylin w bearings. Both vendors provide cad models, the 80/20 autoquote tool is very good, all which make my home made efforts for the remainder of the machine look pretty bad!
    rgrds
    Andrew
    779
    Good luck trying to find anything. CAD libraries like that are very hard to find. Say! Maybe the Zone should start a CAD model library with these types of 3D/2D files in it. The files can be saved in IGES format for 3D and DXF for 2D. I have many 3D and 2D parts I could put in there.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    6855
    Quote Originally Posted by HomeCNC
    We already have a section for that- http://cnczone.com/modules.php?name=...category&cid=6
    Proud owner of a Series II Bridgeport.
    Jan 2004
    3154
    Cold fusion nailed it right on the head.
    www.integratedmechanical.ca
    Nov 2003
    634
    Here's the same thing, but for AutoCad
    http://efunda.tradepub.com/free/pas/
    Jan 2004
    3154
    Quote Originally Posted by buscht
    I believe your link was meant to be for partspec?
    here is a more direct link
    http://ps.cadregister.com/CADREgister.ppow?GB&
    37
    Go to thomasnet.com and look into registering for the partspec CD set.
    There are up to ver. 8 and it is 8 CD's of cad drawings..
    Good thing to have if your doing any type of design work..
  1. =>Access Free CAD Projects
    By CAD Ground in forum News Announcements
    Last Post: 05-23-2005, 07:03 AM
  2. => New CAD Projects Available
    By CAD Ground in forum Employment Opportunity
    Last Post: 05-16-2005, 08:45 PM
  3. CAD Drafters Needed
    Last Post: 03-11-2005, 06:05 PM
  4. CAD Drawings
    By noid in forum Employment Opportunity
    Last Post: 09-30-2004, 04:14 PM
  5. 3D CAD models for free download where?
    By balsaman in forum DIY CNC Router Table Machines
    Last Post: 03-30-2004, 12:59 AM
