Well it's a lot easier if you copy the original transform and just reselect the Op that's getting transformed. 99% of the parameters are the same. The only thing different for your Transform is the Operation that being transformed. Copy & Paste, then re-select the toolpath.
Do you also realize that you can select more than one operation when your doing a transformation! If it's the same tool, dont you use that tool for part #1 (complete), then do all the same toolpaths for part #2?
There's probably a 1/2 dozen things you could do to improve your programming time. The number of operations isn't the question. The questions how long is it taking you to program the part?
What type of training have you had to improve your efficiencies?
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
