586,067 active members*
5,257 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 2100 control Help
    Dec 2008
    I have a machine in the over travel position in Z
    I understand I need to hold the control button in to keep the Hydraulics on but it show a button to push in the manual to press to remove power feed inhibit
    I can't figure out what button I am to push so I can us the hand wheel and move the machine off the over travel
    If anyone could help me with this it would be a big help
    May 2007
    64
    I assume you are talking about a VMC, not sure what you mean by hydraulics. Hold the master start button then jog the axis down, also if the machine is a VMC and the tool carosel is not fully retracted it will inhibit the z axis from moving down.
    Rick
    Jun 2007
    43
    Is it not the data set button?
    Aug 2008
    97
    NO IT IS NOT THE DATA SET BUTTON IT IS THE MACHINE POWER ENABLE GREEN BUTTON THE ONE THAT YOU TURN YOUR CONTROL ON WITH WHEN YOU POWER IT UP. THEN USE THE -Z AXIS JOG BUTTON NOT THE HANDWHEEL.
  1. Acramatic 2100 help!!
    By SBAGHAEI in forum Cincinnati CNC
    Last Post: 07-14-2016, 08:28 PM
  2. siemens acramatic 2100 control
    By jptalon in forum SIEMENS -> GENERAL
    Last Post: 09-19-2012, 12:00 PM
  3. acramatic 2100 control
    By greg b in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-01-2009, 09:33 PM
  4. Acramatic 2100
    By mblazenby in forum Tree
    Last Post: 02-05-2009, 02:30 PM
  5. Acramatic 2100 control parts
    By VSMIGuy in forum Uncategorised MetalWorking Machines
    Last Post: 02-19-2007, 08:23 PM
