I have a Sherline CNC rotary table with the stand alone controller that I want to adapt to my new CNC mill. The stepper motor on the rotary table is a 6 lead 2.5 amp motor that has the 2 center tap wires connected together inside the DIN connector. I do not want to modify it so I can use it in either way. My driver box uses gecko 202's and which only accept a 4 wire setup. so do I just make an adapter cable with a DIN connector that matches the one on the rotary table with the the military connector that I need on the other end to connect to the mill with just the 4 field wires? Does that mean I need to change the resistor on the Gecko from a 3 amp drive to a 1 amp drive since this will be full winding setup?
Thanks for any help
