586,115 active members*
3,458 visitors online*
Thread: Toolpathing
    Dec 2008
    34
    Toolpathing
    Got Gibbscam 2009, trying to toolpath a .042" hole with a .0312" endmill. Went through the setting dialog using bore. Clicked on the hole, but the DO IT button won't highlight. I'm using a dxf imported file. It recognizes the part...so that doesn't seem to be the problem. Adding a second tool to the process under a contour and clicking on the hole got the DO IT button to highlight, but that can't be the right way of doing it. Are my settings in the bore dialog not allowing me to continue?
    Any help would be appreciated.
    Jun 2003
    513
    If you are using any of the hole processes you need points or circles, not a body selection. If you use the hole wizard or manager then you do a body selection and the system creates the geometry for you.
    Dec 2008
    34
    Ya, I came to the same answer on my own through the user manual...tried it and it works
    thanks for confirming
    I'm sure I will need further help through this process...first timer
  1. Automatic Toolpathing
    By camtd in forum Mastercam
    Last Post: 05-29-2007, 03:23 AM
  2. Mastercam 3D toolpathing
    By piratehcky in forum Mastercam
    Last Post: 01-04-2007, 03:35 PM
