586,036 active members*
3,699 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    May 2006
    64
    Exclamation SODICK WIRE EDM MARK 21
    Dear All.
    I have SODICK A500 wire cut edm machine.
    I can not transmit and received data via RS232 interface. I do not known why although i used cable same with fanuc cnc. operation follow with sodick manual.
    Now i must use floppy disk for transmit data from pc.
    I have 02 user disk from sodick but i don't known the way to read and write that disk. For testing I installed windows 98 and windows 2000 but my computer can not read and write floppy.
    Anybody have experiment for this case please show me the way to solve this problem.
    Thanks in advance.
    BKCOM
    Dec 2008
    10
    Mr BKCOM,
    that generation of sodick machines had an specific issue with serial, wich had something to do with the bit transcription of the serial. I can't tell you precisely what that is, but it is not an easy thing to solve with an ordinary pc. Sodick used to provide a separate pc unit to program, with the same soft as the machine, and that worked fine, naturally.
    As wire cut programs don't have so many blocks, they are easy to copy on disks, but you must use the 720k format, instead of the normal 1.44mb. First of all, do not format disks on the machine, but in the pc. If you can format them in 720 (it is an option that win98 normally has), there´s an even more simple solution. 720k format it is not more than a one-side format. Have you ever realized that floppy disks have TWO holes in the corners? One is to protect them from writing, and the other one is to block one side of the disk. Cover it with a tape, and the disk will automatically become into a 720k one. Try these two options, the file extension for sodick is .nc, from a normal text file. You should be able to make it work so.
    PS: this has just one problem. Disks normally become useless after a couple of weeks, due to electric noise from the machine. I found just one solution to that... I bought many of them. Hope was helpful
    Nov 2006
    33
    to fomat floppy 720k on xp or dos download FMTW.exe
    i have it to format on xp po my 720k
    work verry goot
    i have a sodick a530d ..
    if you dont find it on the web replay me
    i have it on zip files si posible to send it to you
    sorry for my english i talk french
    Dec 2006
    131
    the link below is a pinout for the sodick cable. Your cable pinout for the fanuc may be different than the sodick machine. Check in the parameters for parity check and what baud rate the machine is set to also. If you start to get info but it is all messed up change the baud rate. there is a device sold for rs232 connectors that can test the cable coming out of the machine and also the cable coming from the computer. I hope this helps you.
    http://www.sodick.com/forum/showthread.php?t=737
    May 2009
    Regarding Sodick mark 9 BF 275
    Dear sir
    recently I purchased a used Sodick mark 9 BF 275 wire cut macine, the machine is showing an error " SYSTEM ERROR" with red color background, can u tell me where the problem is? if you can help me please send me the details immediately to my e mail : [email protected]
    Thanking you
    Srikrish
    May 2010
    HELLO ,IM USING A350 SS AND FACING PROBLEM WITH SMS BOARD ,VERY FREQUENTLY MOSFETS ARE GETTING FAILED , WIRE GETS BURNED COULD NOT FIND OUT THE PROBLEM , PLEASE HELP ME WITH THIS. PLEASE MAIL ME AT [email protected]
    Dec 2009
    18
    Thanks for the info,
    I've recently purchased a A320D-AWT, & i'am facing the same problem , I am trying to load program from my windows xp , but m/c doesn't reads it , so I Blocked Right Hand Side slot , formatted the disc in the m/c on 720kb & then re-write the program , and again tried to load on the m/c , but m/c doesn't accept it ,
    Should i go for another pc with o/s WIN 98 ? Or any other way out ?
    Systronic:- could u send me files for FMTW.exe
    email:- [email protected]
    May 2010
    Unhappy PLEASE HELP ME
    HI ALL PLEASE help us solvin , I HAVE A350SS SODICK FROM FOUR MONTHS M/C IS NOT WORKING , IF TRY TO RUN M/C, IT RUN'S FOR FEW HOURS AND THE WIRE STARTS TO BURN AND CREATS A MARK(LIKE SOLDRING) ON NOZZLE COVER AND THE MOZFET BLASTS IN SMS BOARD ,AND IF AGAIN WE TRY THE M/C TO RUN AFTER CHANGING THE MOZFET , THE SAME RESULT WE GET , PLEASE HELP ME BY GIVING SUGGETION TO OUT COME THIS PROBLEM,
    M/C IS NOT RUNNING FROM FEW MONTHS.
    IT WOULD BE A GREAT FAVOUR FOR ME.IF POSSIBLE PLEASE MAIL ME AT [email protected]
    SODICK FLOPPY USB DRIVE
    Why dont you just upgrade the floppy to a USB port and eliminate all that.
    Floppy upgrades MARK X, MARK XI, MARK 25, MARK 21 - PLR Electronics Forum
    3 ½ floppy drive to USB flash drive reader upgrade
    Electronics Circuit Board Repairs and Design
    Aug 2007
    I NEED HELP PLEASE ON SODICK A320D EX21
    please can someone help me,i have a problem on my sodick a320d ex21, when it is loading it stops on system loading 12. can anyone help me pls? my email is [email protected]
    Jan 2011
    Sodick Collectioner ask me
    I have 5 Sodick Wire cuts I will be glad to help
    contact 00989175557355
    [email protected]
    I have a bf275 does not move axises during M00 code execution!
    What Should I Do?
    Nov 2010
    Re: SODICK WIRE EDM MARK 21
    I need help. i want to know the actual values of the machine parameters such as ON, OFF, IP, ....
    Also, if any one have the manual please send it to me, i strongly need it.
    Oct 2013
    Smile Re: SODICK WIRE EDM MARK 21
    Hello,
    Parameters for generator are in COND file at USER DISK easilly to readable (720kB floppy) - attached file.
    I don't have most important thing - link between cuting condition and offset ;-(
    If anyone have please send me picture for 0.25mm wire.
    I have couple of picture from original book (not everything sharp enough) - I have got tham from one person from France.
    I have PDF with electrical schemas and machine operation book for Mark25 (almost this same as Mark21).
    Possible to send by e-mail: [email protected]
    Please contact if you need
    Feb 2015
    I have a AG360L. I need help with a 4 axis post. I keep getting a limit error . please help.....
    Mar 2018
    Quote Originally Posted by naveinr View Post
    Hello, I have the same problem , please let me
    Know did you solve it and how ?
    Jun 2018
    5
    Lightbulb
    good day I have an eroding sodick ap500, when I turn it on I am loading at 12%, after turning it off and on again a message comes out in Japanese which says please insert the system disk, after inserting it now the warning is displayed use the instructions of software installation, I do not know what to do, somebody can help me
    [email protected]
    Mar 2019
    Re: SODICK FLOPPY USB DRIVE
    Because you can't be sure that it will work. Sodick tried to put some themselves and they failed and abandoned this way.
    Mar 2019
    Allo. J'ai des problèemes de formatage avec ma Sodick A350W. Pourriez-vous m'envoyer une copie du logiciel FMTW.exe s'il-vous-plaît? Mon adresse: [email protected].
    Jul 2019
    10
    hi
    you can format your floppy disk to 720k
    1-select or type "run" in the windows Startmenu or just press (windows key)+R
    2-in the run dialog type:CMD (press enter )then type
    FORMAT A: /T:80 /N:9 (press enter )
    Jul 2019
    10
    Re: Sodick Collectioner ask me
    Quote Originally Posted by ehsan.amouzegar View Post
    [email protected]
    What Should I Do?
    Hello
    I have Sodick A530D EX2 ,and have some problems ,when I turn on the machine ,on the screen displays (E229 system fault ) error can I fix it and how.
    And I want the change language from German to English ,how can I change it .
    Thank you and have a nace day
Page 1 of 2 12
  1. sodick mark ix wire cut EDW nec 9801 uv problem
    By Simon.muthike in forum EDM Discussion General Topics
    Last Post: 10-11-2023, 12:00 PM
  2. Sodick A3C-R with MARK IV controll
    By djezowski in forum EDM Discussion General Topics
    Last Post: 01-20-2013, 07:50 PM
  3. Sodick Mark XI EDW AWT Error
    By CDM_EDM in forum EDM Discussion General Topics
    Last Post: 04-05-2012, 04:22 AM
  4. Sodick A280L-Mark EX Alarm!
    By C&L Mfg in forum EDM Discussion General Topics
    Last Post: 07-28-2009, 09:32 PM
  5. Sodick Mark X1B EDM Machine
    By rajappa in forum DNC Problems and Solutions
    Last Post: 10-23-2007, 03:56 PM
