586,113 active members*
3,242 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > WinCnc > WinCNC screen with lots of buttons
    Mar 2005
    214
    Here's a screen I'm using with lots of buttons. I use a several fixtures quite often so I have buttons assigned for their positions, toolsetter, little bits of gcode, macros etc. Saves me time and some brainpower.
    Unzip the cncscrn zip, replace your "cncscrn" file in your Wincnc folder with "cncscrn - blank", rename it "cncscrn" and your good to go. Save the original in case you want to switch back. Open your new one up in Notepad, scroll down to the lines like this:
    "UserBtn",60,25,50,25,1,0,"BUTT 1","xxx","",-1,-1,""
    Each line is the size and position of each button. Change "BUTT 1" to a name you want to use and "xxx" to the gcode you want to run. Modify to suit.
    Attached Files Attached Files
    www.harryhamilldesigns.com
    CAD sculpting and services
    Feb 2004
    83
    Harry,
    Thanks for posting. Makes life so much easier when setting up WinCnc.
    Jack
    Jan 2011
    Thanks for sharing a great looking screen-
  1. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  2. buttons going out? need help
    By DerHammer in forum Fanuc
    Last Post: 03-10-2008, 04:25 AM
  3. Programing AUX buttons
    By George C in forum Centroid CNC Control Products
    Last Post: 02-10-2007, 08:33 PM
