586,104 active members*
3,219 visitors online*
Thread: New Wizard
Page 4 of 4 234
Results 61 to 77 of 77
  1. #61
    May 2005
    925
    Quote Originally Posted by Shinosky View Post
    Here also is the screenset I have been using. The circle wizard actually started out as page two in the screenset, and still is. I broke it out to be a stand alone wizard for anyone else. The screen is actually a little different from this shot.
    Because the Circle routines are actually a part of the main screenset it loads instantly so it's easy to create a roughing path then bounce right back and create a finish pass. All the values are still there.
    Andy
    Andy, kudos on your work!!!
    May I suggest some more items for your screen? There is space if you remove that big Mach3 banner at the button
    Add:
    Last used wizard
    NFS wizards (for us licensed users)
    Buttons for selecting offsets (G54 thru G59)
    Spindle control
    and add the settings/diagnostics screens.
    Thanks again for sharing it
    Pablo
  2. #62
    May 2006
    309
    I got a g53 code at the end when I tried this wizzard and that sent my Z axis down to -50 when I ran it offline.
    Why does it generate this code?
  3. #63
    Oct 2006
    51
    The code was set up to switch to machine coordinates and then send the z axis to the home position. If you don't like this behavior you can always edit the gcode and delete this line out of the code. Part of the problem may be that you haven't ref'ed the machine. The Z should move up to the top of the travel when homed.
  4. #64
    Oct 2007
    152
    Hi, congrat for the nice wizard but I'm having trouble with it I don't know if this is normal but the safe Z and the total depth seems to add up together. Whenever I make a modification to the safe Z in reveals in the G code and my router plunge to that deepness. here is he pic I have measured it and it is .375 deep and the code his highlighted? By the way you wouldn't have a wizard to create an oval ( ELLIPSE ).
    Thank you
    http://image75.webshots.com/75/7/19/...6EJyrRg_fs.jpg
  5. #65
    Oct 2006
    51
    Hey Bobinette,
    I'd like to try and fix your problem but the jpg you posted won't display. I get a "forbidden" error message. What are the values you put into the Safe Z and Total Depth Dialog boxes?
    I do not have any plans to create an ellipse wizard any time soon....sorry. I am just swamped with other projects.
  6. #66
    Oct 2007
    152
    Thank you for your help, for the pic I will ry it out this way, hope it works, a pic is suppose to worth a thosands words
  7. #67
    Oct 2006
    51
    Everything looks fine on the dialog. Could you please copy and paste the resulting Gcode? It would help me to see what might have happened.
    Thanks....Andy
  8. #68
    Oct 2007
    152
    Hi, here is the code and if you take a look at the pic, where it is hihglighted you can see the Z 0.35 ?
    ( CUT A 3 INCH DIA. CIRCLE)
    ( TOOL DIA. 0.25)
    ( 2 STEPS @ 0.125 PER STEP )
    ( TOTAL DEPTH OF 0.25 INCHES )
    G0 G49 G40 G20 G17 G80 G50 G90
    M6 T1
    M3 S1200
    M7
    M8
    G00 Z0.35 Is this ok?
    G00 X3.25 Y1.75
    G00 Z0.1
    G01 Z-0.125F10
    G03 X0.25 Y1.75 R1.5 F20
    G03 X3.25 Y1.75 R1.5
    G01 Z-0.25F10
    G00 Z0.1
    G53 Z-.1
    M5 M9
    M30
  9. #69
    Oct 2006
    51
    Ok, I haven't looked at this in a while so I had to refresh my memory. that initial move in the Z axis takes the cutter down to the Safe Z Dimension plus .25" but only on the initial move. Whenever the cutter comes up for a positional move it does so at the programmed Safe Z level. I think I did this because I didn't like my machine making an initial rapid move down so close to the part I don't see anything in the code you posted that would cause the tool to gouge or plunge deeper than the programed max depth. Let me know if I have missed something.
    Andy
  10. #70
    Oct 2007
    152
    Hi, first off all I want to be sure about the safe Z, the one you are talking about is in the config/safe_Z set up ?
    If this is the right one, I tryed to change some settings in it and it didn't change anything, I would admit that I don't know what to place where in these settings and many more( I guest that Rome wasn't built in a day).
    The only thing that I have learned is clicking on Go to Z on the main screen brings me back to my original position, at least I have learn something new.
    Sthill a lot to learn
  11. #71
    He's talking about the SafeZ setting in the wizard.
  12. #72
    May 2007
    6
    Thanks for sharing your great work
  13. #73
    Dec 2007
    28
    I know this is an old thread but I'm hopful that someone's watching. I just downloaded the plugin and when I fill everything in and click Post Code nothing happens. I don't get any code. Here's the screen shot of how I completed the form.
    Attached Files Attached Files
  14. #74
    Oct 2006
    51
    I have a couple of questions. The first is the obvious. Did you put the macro files in the proper folder? When you click to post it should be running the Macro and it apparently is not. Another possibility is that you use a custom profile. If that is the case then the macro needs to go into the macro folder under the custom profile name in your Mach directory.
    Hope this helps. I haven't looked at this stuff for a while
  15. #75
    Dec 2007
    28
    That was it. I have a custom profile. I moved the files and it works great. Thanks for an awesome app!
  16. #76
    Dec 2006
    60
    Great Wizard.
    Thanks very much for sharing your circle routine. The graphics are great and the program works great. I wish I could do so well.
    For those who are running Mach3 with the Syil X3 configuration setup, the "M700.m1s" file has to be in Mach3--->Macros--->SyilAmericaX3. Then things will work great.
    Thanks again.
    OM
  17. #77
    Feb 2005
    234
    Rectangular multiple drill update ?
    Is there a better wizard/plugin tHat I do not know of rather than the one already on the wizard ?
    That's the only one that can not "save" the input after you exit the wizard ?
    I need to drill many holes in rectangular shapes, very quickly.
    There is no "save" button on the rectangular drill wizard.
    So everytime i enter I have to input all over again.
    I hope that's the old version of the wizard.
    Help ....
    C
Page 4 of 4 234
  1. Need Wizard
    By mungaro in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2008, 10:59 PM
  2. Hole wizard
    By villiersterrace in forum Solidworks
    Last Post: 12-18-2007, 10:47 PM
  3. Nesting Wizard, Mach3 internal wizard.
    By thuffner3 in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2007, 03:38 AM
  4. Disabling Help Wizard
    By kentavv in forum Mach Software (ArtSoft software)
    Last Post: 02-20-2007, 05:40 AM
  5. Need Wizard/Screen Help
    By elalto in forum Mach Wizards, Macros, & Addons
    Last Post: 08-10-2005, 12:08 AM
