586,082 active members*
3,772 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Is there a way to have BC print out a Blue Print of a drawling?
    Jul 2007
    129
    With a border, company info,ect. If so, how?
    Thanks.
    Jun 2008
    1838
    Quote Originally Posted by Stampede View Post
    Thanks.
    Not that I know of, best I reckon you could do would be to draw a "blank" one with boxes you can put text into and use it as a base template for your drawings.
    Or, you could go here http://www.alibre.com/support/downloads.aspx and download the FREE "Express" version which has that facility built in and will Import your BobCAD file as a DXF, you can also download free "PDF Creator" which will print out the drawing as a PDF file in various sizes such as A3, A4 etc, etc.
    See screen grab below.
    Regards
    Rob
    Jun 2008
    1838
    Thanks.
    Stampede
    Here is what you can do with a little work in BobCAD, I cheated and just imported a .dxf just for speed and demo.
    Bit "rough and ready" but should be good enoughto get the idea across I hope!!
    You can simply draw up something like the one I`ve done in the attached files and then save it out as anything, I chose "BobCAD Blank" for the demo. Then you can just open it do your drawing and save first as a .bbcd under a different name so you could re-open in BobCAD if any alterations were needed. Then if you have downloaded the PDFCreator you only need to click File > Print > and select "PDFCreator" as the printer and it will create a .pdf file that you can print off to whatever size your printer will handle.
    I`ve attached the .bbcd file and the .pdf for you.
    Hope the idea works for you, maybe BobCAD will pick up this ball and run with it???
    Regards
    Rob
    Attached Files Attached Files
    Apr 2007
    12
    Smile wOw
    Good friggin' job, that looks ggrrrrrrrrrreat !!!
  1. How to print ion a 3d surface
    By whiteriver in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-20-2010, 10:39 PM
  2. cant print?
    By erase42 in forum BobCad-Cam
    Last Post: 11-30-2009, 03:05 PM
  3. No Print or Drawing
    By operations1 in forum DynaTorch
    Last Post: 10-02-2008, 12:57 AM
  4. 0.8 um Symbol on print ?
    By RMARCH in forum MetalWork Discussion
    Last Post: 12-01-2007, 04:55 AM
  5. Blue print creation
    By mroy0404 in forum Mastercam
    Last Post: 11-21-2006, 11:38 PM
