586,058 active members*
3,419 visitors online*
Page 1 of 2 12
Results 1 to 20 of 30
    Nov 2004
    Haas Visual Quick Code (VQC)
    Hello,
    Lets see if we can get something going here for ideas on templates for VQC.
    It would be neat if we could even exchange templates. Lets hear how you have modified VQC program.
    Have a great day!!!! :cheers:
    Apr 2003
    1873
    ethal68 -
    I have never used this feature so I am very interested in seeing how this may be used as well.
    I wish I had some useful input for users of VQC.
    Ken
    Oct 2003
    352
    I have an "04 VF-5/50 with all the bells and whistles. I have downloaded the Haas VQC software from the website; however, I have not taken the time to play with it much. I want to set up some templates for my probe more than anything. I will try to start going through it this afternoon. Hopefully I will lhave something good to share in a day or two.
    Mar 2004
    761
    There is a freeware version of CNC Quick Code for the HAAS at:
    http://www.machinist-toolbox.com/qcode.htm
    It has more features than the one from HAAS.
    Oct 2004
    116
    Hi guys,
    I used VQC on a tool room mill a few years ago. The only thing I ever did was simple hole patterns. But it did work very well. It only took a few min to produce a lot of holes.
    Dalen
    Jun 2005
    116
    Haas VQC
    Hi
    We use VQC on our Haas VF3 just about every day we find it has taught a lot about G code with out the hard study this has also helped with a lathe.
    Have not learnt how to add to VQS yet but this is the next step. i hope to learn from this thread.
    Best Regards
    Burgs
    Jul 2005
    14
    Since nothing on VQC has been posted in here except good intentions and interest to learn, I thought I'd post a segment from an older manual for creating/customizing VQC templetes. I'll post more as I have time.
    Attached Files Attached Files
    Nov 2005
    196
    I was able to add a VQC template to our Haas SL-40 lathe. I'll be glad to lend a hand if anyone wants to give it a try.
    Nov 2005
    Hello Everyone, I will try and answer any question regarding the workings of VQC.
    Feb 2006
    22
    Question Probe
    has anyone ever used haas for probing coordinates
    and if so how well did it work.
    thanks
    bob m
    Jun 2005
    95
    We have two MiniMills at the Community College. One is equipped with a Renishaw OMP40 work probe. We use it extensively for setup (establishing or updating work offsets) as well as in-process inspection. As for reverse engineering, I think a CMM is better suited.
    All of the probe calibration cycles as well as measuring cycles are done using Renishaw's Inspection Plus macros, which are loaded into the HAAS controller as part of the optional package. Programming is very easy and output to a PC for data collection or inspection report is extremely user friendly.
    If you would like sample code, let me know and I will post it.
    May 2006
    4
    Bill T.
    Quote Originally Posted by MIDDEN300
    thanks
    bob m
    Bob,
    I just purchase one on my new haas mill and it really is sweet for setting tools and you don't need to use an end finder any more or an indicator for finding the center . I haven't used it long so I don't know how well it will work over the long haul but right now I really like it. I leave it in the tool changer and call on it when I need it.
    Bill T.
    Jun 2006
    11
    i have done very little inspection work with our probe and have had some succes using it. i was looking for some help on saving multable probe data in a variable and then printing all the recorded data in one (w) print cycle any info would be helpful
    Mar 2005
    1498
    060630-0652 EST USA
    carguy001:
    Your question would probably get more attention under HAAS in its own thread instead of under VQC.
    Why do you want to dump all the data at once?
    If you send many DPRNT statements at one time your can overflow the HAAS output buffer, even at 115.2 kbaud. It is better to spread these in time. Also if you have a large number of data points you might have a shortage of available variables. Using a large number of variables creates a management or definition problem.
    Jun 2006
    11
    thanks gar i will put something in the haas thread but do you know how to store the data to a variable and then print from the variable
    thanks again
    Mar 2005
    1498
    060630-0747 EST USA
    carguy001:
    Assume the X-axis value you want to output is in variable #501, then the following statement will output whatever is in #501:
    DPRNT [ X#501[24] ---- 501 VALUE.]
    If #501 contained 4.7641, then the resultant printed output would be
    X 4.7641 ---- 501 VALUE.
    Jun 2006
    11
    thanks gar
    i will play around with this a little bit and see what happens i look at your other posts and think that will also help
    Nov 2006
    36
    Why don't they have a Square pocket milling VQC template?
    May 2006
    4
    Is that not called frame milling.
    Nov 2006
    36
    Hmmmm I don't know. I don't remember seeing frame milling in the menu selections either. I'll have to look tomorrow
Page 1 of 2 12
  1. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  2. HAAS Indexer Prodramming / Control
    By CAMmando in forum Haas Mills
    Last Post: 06-10-2003, 04:22 PM
