586,221 active members*
3,630 visitors online*
Results 1 to 11 of 11
    Dec 2008
    DynaMyte 2400 Manuals
    Hello!
    I recently acquired a Dyna Myte 2400, does anyone per chance know where I might find a manual for this?
    Also, I've read some rumors that this CNC is not programmed with M or G codes, can anyone validate this for me??
    Thanks in Advance!
    Jun 2008
    dyna mechatronics manual
    I have 2 dyna mechatronics and i work evry day.....
    if you wat the manual send me your mail.
    Bye!
    Feb 2007
    456
    I have a Dyna 2400 I use at my 'day job'. I have a scan of the manual around somewhere. If I can find it I'll send you a copy.
    The Dyna controller is programmed in their on 'conversational' language. It's not too different from GCode. The biggest problem is the very limited 900 line memory. Several years ago I wrote a 'drip feeding' program to send it commands one at a time via the serial link and this worked OK. Depending on your firmware version it would work 90% of the time.
    A few years ago I converted it to Mach III and have not looked back. I used all the stock drives and power supply and a home-made opto-isolated break out board (so the stock wiring just plugged right in.) You could use any available BOB though. I have a SmoothStepper from another project that I'm just waiting to try out on it too, so I can get away from being tied to the parallel port.
    Jeff Birt
    Jun 2009
    16
    Quote Originally Posted by VrSixed View Post
    Hello!
    Thanks in Advance!
    I know this is an old thread, but in case anyone needs them I have pdf's of the manuals. PM me your email and I can send them to you (for free, unlike some it seems...)
    Feb 2007
    456
    I'm not sure if that was directed at me or if it was even called for, period...
    Hmm...I put this up for download in April and mentioned it here on CNC Zone but I guess did not update this thread. Seems like there may have been a few different requests about the same time. Here is the download URL.
    http://soigeneris.com/Documents/Dyna2400_Manuals.zip
    Jeff Birt
    Jun 2009
    16
    My apologies --- wasn't directed at you. In fact I think the copies I have are from you, though not directly
    I'd been searching for manuals and kept running across people charging them. I think one guy mentioned it cost him $100 to get them!
    Quote Originally Posted by Jeff-Birt View Post
    Oct 2004
    the link above doesn't work for me. Can somebody check or verify, please?
    Göran
    Feb 2007
    456
    Sorry, I was trying to make the docs free to all but outside links to other websites are not allowed. If you replace 'cnczone' in the link with 'soigeneris' you should still be able to download them.
    Jeff Birt
    Oct 2004
    Wonderful, worked great. Thank you,
    Göran
    May 2009
    15
    I just got one these machine, I can't get the link to the manuals download to work even with the substitution in the url...is it me or is the link broken?
    Feb 2007
    456
    Nope they are still available you need to do the following take this URL:
    http://cnczone.com/Documents/Dyna2400_Manuals.zip
    remove this part: cnczone
    and replace it with : soigeneris
    I know it is a PITA but thems the rules...
    Jeff Birt
  1. DynaMyte 2400 spindle bearings
    By polytone in forum Benchtop Machines
    Last Post: 06-16-2015, 09:58 PM
  2. Dynamyte 2800 Manuals
    By bender88 in forum Benchtop Machines
    Last Post: 12-06-2014, 07:05 PM
  3. Dyna Myte 2400 Manuals
    By azbret in forum Want To Buy...Need help!
    Last Post: 05-23-2011, 09:26 AM
  4. Dynamyte 4400
    By olhippiebiker in forum Uncategorised MetalWorking Machines
    Last Post: 06-22-2007, 06:08 AM
