I want to manufacture plastic cast molds on a CNC machine. The products will be designed in CAD and milled into molds which i could put together and fill with the plastic resin. Thats the idea anyway but thats about as far as I have got. I need to know if its concievable that a milled peice could have a surface smooth enough to then mould say a clear lens for a taillight. Maybe with some minor buffing or sanding? If i had a 18"x18"x6" approximate working area is there a machine that jumps out as an ideal for this scenario? is it under $5000 i hope? Thanks a lot guys. First post btw I look foward to getting to know a lot of you.
