586,626 active members*
2,482 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Jul 2006
    142
    odd X Axis issue
    Been awhile, the Fadal has been running well for the last few months.
    But there is always a catch. Recently, I get a X axis fault #17. I shut the machine down, power back up, do the CS, and off and running again.
    Today is where it gets weird....
    Had a part shift, broke the endmill, and some vibration from the spindle due to the endmill now in the shape of a Ball. Replace the endmill, perform the CS and go to move the table with the JOGWHEEL, and the table takes off full tilt in the X axis, full speed!! Scared the heck outta me.
    Now, shutting the machine off and re-boot, does no good. Messed around with it for an hour or so, swapped the Y to the X, fault followed to the Y. So, I;m thinking I have a driver board not playing nice.
    So, took a break, beat on the kids for some evening fun, and went back out.
    Got the CS to take, but again, when jogging the table, in the X axis, the table will move on it's own, the more I turn the wheel, the faster the table moves.
    What the heck is this all about?
    What a way to start the New Year!! YEE HAW!!
    Smitty
    900
    Smittys800--
    The error #17 indicates a pluse count at the zero cross over is too large. The problem would most normally be either the 1010 controller card, the resolver feed back cable of the resolver itself.
    I hope that helps.
    Neal
    Jul 2006
    142
    Thanks Neal,
    Will look into that. As for the Resolver, is that something that can be cleaned, and is that located in the servo motor.
    Smitty
    Jul 2006
    142
    Little update...
    Spoke with Keith at K-Mac today, his thought was the Resolver. So, once I got home, removed the resolver, blew out some dust, re-assembled, and threw the switch!
    Well, the table did not mis-behave, so after and hour of running a program, with no spindle, just cutting air if you will, let er go, so far so good, but I do think I am on borrowed time with the resolver. Once I get some stuff done, will install a new unit.
    HUGE thanks to Neal and Keith at K-mac.
    Enjoy the weekend, I'm stuck workin!!!
    Smitty
    Feb 2008
    547
    Thanks for the feedback!!
    Love hearing the outcome of problems. Sometimes people do not update after a solution is tried and it is great to have this stuff for the arcives!!
    Steve
    Jul 2006
    142
    Totally agree!!
    That is why I came back with some sort of update, just hope it may help others.
    Smitty
    900
    Smitty--
    Me to, what he said!!
    Neal :=))
    Jul 2006
    142
    Guess who is back in town!!
    Was working the good ol FADAL tonight, and boom, error 17 on the x-axis.
    Was able to get a CS to take once, touched the jog wheel, and the table just took off at Mach 9. Went about 6" and stopped. Hit the jog button to reset the drives, and no one wants to play anymore.
    Looks like it's time to order that resolver, @@@@@
    Smitty
    Jul 2006
    142
    More updates to the update,
    Pulled the Resolver from the servo, and there is some serious BADNESS in there.
    Will only turn, maybe 180 deg. before it stops..... So off the Kmac for more goodies.
    As usual, I will update my updates,
    Enjoy the weekend,
    Smitty
    Jul 2006
    142
    I hope people DO read these, and I'm not just taking up space.
    Took the resolver apart, found the bearings siezed up, so have a new unit from the Boys at K mack on the way!
    Feb 2008
    547
    We do read these and thank you for the follow ups. It sounds like maybe moisture may have gotten to the bearings. Can you tell?
    Steve
    Jul 2006
    142
    No moisture that I can see, very dry inside the case. Actually the outer case of the resolver looks new. But I'm sure this machine has TONS of hours since I bought it used. Slowly it is getting the TLC is so badly needs@!
    Should have the new part on Wensday, and go from there.
    Smitty
    900
    More people read these than you would imagine!
    Neal
    Mar 2007
    23
    I run two Fadal 15XTs at work and completely seized resolver is pretty common problem. Happens once or twice in few years.
    Its good to have spare motor and resolver around always.
    Jul 2006
    142
    Wish that was the case here!!!
    BIG BOOM today.
    Installed new Resolver Friday, no change.
    Found a local FADAL repair tech, got one from him, same deal.
    So, did some digging, found that the servo had been re-wired at some point for the old resolver.
    Well, the reason for the big boom is still unknown, what happened....
    Re-installed the first resolver, hit the jog button, and the table took off so fast to the left, that I totally missed the E-stop, table just about went through the left door, BANG.
    Pulled the STOP rod out of the bearing block, and was nice enough to spin all those little itty, bitty balls from the screw... all over the floor.
    So, as for now, I am totally screwed.
    More to come as we dig into this little wonder!
    Smitty
    Mar 2007
    23
    OUCH!
    If i were you i would double check all resolver and motor related wiring from axis cards to motor if there is partly broken wire. Happened with one of mine 15XT once.
    Jul 2006
    142
    Been a while, figured I'd update.
    After working the street corners, stealing the kids allowance money, and begging in general, got it back together today.
    What I found was....
    The servo that was on the machine was not OEM, and had some ingenous wiring to boot, so all in all, after the ball screw repair and a new Servo motor, flipped the switch, closed my eyes and ran.
    So far, seems to be working ok, will toss some chips in the AM and see what happens.
    Smitty
    Jul 2009
    317
    WHEN WORKING WITH SERVO MOTORS RESOLVERS, BETTER OFF TO REMOVE THE MOTOR FROM THE MACHINE.
    Nov 2007
    78
    I had a memory corruption error and my table took off in the Y direction. I put my hand on the vise and tried to stop it. Didnt work however. Thankfully my table was only on impulse power and I was able to hit the EStop before it ran out of travel. I was not quite so lucky however on X when again, I had a memory corruption error pop up and this time the table banged the end of the screw block. Thankfully again, no damage except my ego I did not hit the EStop in good time.
    Now, I know what is causing my memory corruption. I changed the System board from Sys 96 to Sys97, to Sys101.3 and it was not happy I did not do a memory erase to eash of the system boards.
    the one thing I cannot get to work is downloading of my programs from the MACHINE to the laptop with CIMCO Edit. I dont have a floppy disk drive in my machine to be able to output to. 1993 machine.
    Jul 2009
    317
    USE THE RS232 PORT FROM THE MACHINE TO YOUR PC(NO LAPTOP)
Page 1 of 2 12
  1. Partner 4 Z axis issue
    By ozturbo in forum Milltronics
    Last Post: 03-22-2008, 04:29 AM
  2. DIY controler X-axis issue
    By KsiR in forum Stepper Motors / Drives
    Last Post: 02-20-2008, 03:56 AM
  3. 4th axis power issue
    By Legion99999 in forum Syil Products
    Last Post: 01-16-2008, 07:48 PM
  4. Y-Axis issue
    By studysession in forum Machines running Mach Software
    Last Post: 12-28-2006, 09:11 PM
  5. A axis brake issue
    By nervis1 in forum Post Processors for MC
    Last Post: 04-18-2006, 02:46 AM
